Programers??
Discussion in '1st Gen. Tacomas (1995-2004)' started by broken taco, Dec 5, 2013.
  1. Dec 5, 2013 at 9:33 PM
    broken taco
    broken taco [OP] Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    I have a 2001 Tacoma. I have a code reader that I plug in under the dash to see what codes it is throwing when the check engine light is on. I have heard of programmers you plug into the same spot and you can tell you truck what size tires you are running, when to shift gears, and what altitude you are at.
    I basically want this for the tire size and to tell it what altitude I'm at. I go to college at NAU which is 7,000 ft or more. And I notice a huge loss of power from when I am down in San Diego. Does anyone know of anything like this for the tacoma? or do they not make them for Tacomas?
  2. Dec 6, 2013 at 11:37 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    anyone? someone gotta know something
  3. Dec 6, 2013 at 11:49 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    of course you loose power at 7,000'...way less oxegyen there..its like starving your motor. Totally normal. try it a 10,000 or 13,000 some time..
    I don't know of any device that plugs into your OB2 port that tells you elevation..pretty sure thats not possible. If you want that get a GPS.
    the two popular choices are Scan gauge II or Ultra Gauge.
    then there are just generic code readers out there
    you can recalibrate them for larger tires to get a more accurate speed and milage guess.
    but nothing you can get will change the shift points. ONly a fully reprogrammed ECU will do that.
  4. Dec 7, 2013 at 1:59 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Ok thanks. Thats what I wanted to know!
