programmable TPMS???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cascadetaco, Mar 28, 2017.
  1. Mar 28, 2017 at 2:53 PM
    cascadetaco
    cascadetaco [OP] Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    I am having a hell of a time getting a set of programmable sensors cloned to my factory sensors. Les Schwab my local shop cant read the factory sensors with their equipment? Any one have any luck. I talked to one fella on here that said he was able to get the Schrader Ez sensors cloned. But I have talked to 2 shops, Schrader and Autel and no one has a clue.
    Please help! I want to be able to change my winter set to summer myself without having to take truck in!!!
  2. Mar 28, 2017 at 3:12 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Got a base model SR just like you man and I made one of these pieces of pipe with 2 ends and a valve stem and thru it under my storage bins under my back seats in my access cab and its been in there since February 2015 and works great! Just put some padding in there with my tpms sensors and filled it to 32 psi! Put regular valve stems in my wheels! Cost me about $20 in parts to make one. If your interested pm me and we can talk about me making you one!
  3. Mar 28, 2017 at 3:25 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    PMed you Corey!
    moe2o4 likes this.
  4. Mar 28, 2017 at 4:02 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I'm in the same boat, Schrader does not list a 2016 and up Tacoma on their website for the easy sensor yet. The programmable sensors were they clone your original ID is the ideal solution. I called American tire and they said they can do it but I haven't made it there yet
  5. Mar 28, 2017 at 4:44 PM
    cascadetaco
    central oregon
    This is my gals truck. I dont trust her to check her tire pressure. I want the system to work. (no pipe bombs) But I dont want to take it in to swap winter/summer wheels.
  6. Mar 28, 2017 at 4:50 PM
    moe2o4
    Corey
    Pittsburgh PA
    Well it's gonna cost you probably twice a year for someone to remove the tires....
  7. Mar 28, 2017 at 5:09 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Out of curiosity, is it possible that Toyotas now accept 2 full sets of TPMS transponders?
    This is a bit complicated so stay with me here:
    I bought AT tires and new wheels, as well as new OEM Toyota sensors because they wouldn't fit.
    The dealer programmed them for me and gave me a sheet of paper with both sets of transponder numbers.
    I got another set of wheels through a trade, and swapped both the tires and sensors off my OE steelies onto this set (because the steel wheel sensors DID fit these wheels).
    I'm moving long distance in a week so I swapped from AT tires set back to the OE Highway tire set.
    My TPMS has not started yelling at me even when I drove ~20 miles around town doing errands.
    I'd have thought it would have started bitching about a communication error by now, so is it possible both sets are programmed to the truck?!
    Or, is it just that my AT tires are sending happy beams to the sensor while I'm parked in the garage next to the stack of tires?:rofl:
  8. Mar 28, 2017 at 5:25 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Local Toyota dealership told me the truck can only be programmed to four sensors at a time. And I believe the truck has to be moving for the sensors to read pressure, so I don't think your nearby-stacked tires should be communicating with the truck.
  9. Mar 28, 2017 at 5:49 PM
    Hiluxski
    Ventura California
    The perfect solution are the Schrader easy sensors , cloned TPMS sensors. They clone the new sensor to your old sensor ID # so you could swap between several sets of wheels and tires anytime you want.
    dawhoo and 0210 like this.
  10. Mar 29, 2017 at 11:23 AM
    cascadetaco
    central oregon
    Yes thats the solution I want...if I can only find a shop able to do it. Even Schrader says its impossible till the programmers are updated.
  11. Mar 29, 2017 at 11:23 AM
    cascadetaco
    central oregon
    I have 2 sets of wheels. Stock steelies for studs, and a take off set of offroad wheels for summer duty.
  12. Mar 29, 2017 at 11:36 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    This is pure genius. You should patent and sell this.
    moe2o4[QUOTED] likes this.
  13. Mar 29, 2017 at 12:06 PM
    moe2o4
    Corey
    Pittsburgh PA
    LOL I don't know about going that far but I can make them for people!
  14. Mar 29, 2017 at 12:34 PM
    cascadetaco
    central oregon
    I just got an email back from Autel. They say the mx315 ($30 a pop) sensors and the TS401 programmer ($120 on Amazon) would be a diy solution.
    Bad news is...I had the tires balanced and mounted them yesterday with no sensors. I had to get the studs off before I wore them out on the bare roads.
    Going to drive with the light on till next change over I guess.
  15. Mar 29, 2017 at 12:35 PM
    Hiluxski
    Ventura California
    Take the 4 tpms original sensors and mount them in the spare. Problem solved
  16. Mar 29, 2017 at 1:45 PM
    mipaku
    mipaku New Member
    2017 QS Tac
    How would you put 4 sensors in one spare tire?
  17. Mar 29, 2017 at 3:37 PM
    Hiluxski
    Ventura California
    Dismount the spare tire remove the original rubber valve stem insert tire pressure monitor, drill three other holes across from each other creating a cross insert the other three sensors remount tire balance operation complete.
    Dismount the spare tire leave the valve stem in take the four sensors use a quality duct tape, duct tape them to the inside of the wheel in a pattern to distribute them evenly. Remount the tire balance operation complete.
  18. Mar 29, 2017 at 7:26 PM
    cascadetaco
    central oregon
    I want the TPMS to work. I dont get why anyone would not want it to work...pipe bombs and spare tire makes no sense to me. Call me crazy lol.
    bamataco4x4, dawhoo and oilslick like this.
