programmer
Discussion in 'Performance and Tuning' started by toybalt, Dec 13, 2012.
  1. Dec 13, 2012 at 8:53 PM
    toybalt
    toybalt [OP] New Member
    Chad
    palmetto fl
    08 base
    after market cat k&n filter bigger tires HIDs
    08 2.7 base. looking for a tuner. any suggestions?
  2. Dec 13, 2012 at 10:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How much do you want to spend?
  3. Dec 14, 2012 at 7:42 AM
    toybalt
    Chad
    palmetto fl
    08 base
    Like 500 or so nothing to special but not something dirt cheap
  4. Dec 14, 2012 at 8:05 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Unichip may be a good candidate for you
  5. Dec 14, 2012 at 8:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  6. Jan 2, 2013 at 10:13 AM
    Shipwreck
    Shipwreck Well-Known Member
    Johan
    Centennial CO
    2016 TRD Off Road Tacoma
    Stock
    The unichip is an awesome product. Had it on my Tundra.... WOW!!!
  7. Jan 2, 2013 at 10:22 AM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Doesn't look like they make a unichip for the 2.7's just 4.0's
  8. Jan 3, 2013 at 7:44 AM
    Shipwreck
    Johan
    Centennial CO
    Stock
    Actually that is not 100% correct. I used to work VERY close with Dastek in South Africa and the unichip got its name from being a universal chip. We installed a unichip on a 2007 Suzuki GSXR 1000 too. You can sodder the unichips wire into the trucks ECU. Now if there is a schematic for the wireing for your trucks ECU its as easy as just tapping into those wires. If youd like I can get you in contact with the Brains behind the Unichip here in the USA. Their HQ is in Origon.
    The unichip, with the install and the dyno tune with run you a few 100 bux but it is soooo well worth it. i had it on a 2002 tundra and i gained 7RWHP. I know it doesnt sound like much but I could seriously feel the differance. I could get the truck out the line and up to the limiter which was 110mph in no time and I am a mile above sea level.
    Great product, lot of leg work but you will not be disapointed....
    Oh and btw, DO NOT go for the generic map should you be offered one, rather go to an approved tuner for a custom tume on a dyno.
  9. Jan 5, 2013 at 11:42 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
