Programming Instructions Of OEM Wireless Remote Transmitters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Jan 6, 2009.
  1. Sep 7, 2016 at 8:55 PM
    #41
    Budcat2
    Budcat2 New Member
    Bud
    Mercer Island
    2015 TRD Sport Silver
    None yet --- they will come
    I have verified the following steps will work on a 2015... hope this helps.
    Program remote transmitter when added, replaced or because of a system malfunction
    • Driver’ door open, all other doors closed
    • Within 5 seconds:
      • Insert and remove the key from the ignition switch twice
    • Within 40 seconds:
      • Close and open deriver’s door twice.
      • Close and open driver’s door twice
      • Insert the key into the ignition switch and close the driver’s door
      • Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes
      • twice to program a remote transmitter code whilst erasing the original codes.
      • Three time to check how many remote transmitters are currently registered
      • five times to erase all registered codes.
      • Remove key from ignition switch
    • System should now lock and unlock vehicle once, twice or five times depending which mode has been selected or one to four times, slowly, to indicate number of remote transmitters registered.
    • Within 45 seconds:
      • Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
    • Within 3 seconds: Press and release LOCK or UNLOCK button
    • System should now lock and unlock vehicle once to confirm registration twice to indicate registration has failed
    • Within 45 seconds: Repeat button procedure to program remaining remote transmitters
    • NOTE: To exit programming mode: Open driver’s door.
    • NOTE: A maximum of 4 remote transmitters can be programmed
    Brad2011TRD likes this.
  2. Feb 18, 2017 at 5:00 PM
    #42
    SQFrederick
    SQFrederick New Member
    Sam
    2006 Double Cab TRD Sport SR5
    None
    Thanks for this post! I had an appointment to spend a small fortune at the dealership for a FOB and a key. Instead, I got 2 FOBs, a key, and programmer for the keys on Amazon for $60! FOBs both work great and I'm just waiting for the key programmer. Hopefully, that goes smoothly as well!
    One question for you all though. According to the instructions, after successfully programming a FOB, the doors are supposed to cycle once if it works right and twice if there is an error. When I finished, it cycled twice after each FOB, but they both work. Any ideas why it would cycle twice and is this something I should be concerned about?
    Not sure if it makes a difference, but I have a 2006 double cab, TRD Sport, SR5.
  3. Feb 8, 2018 at 1:51 PM
    #43
    Ralmoho
    Ralmoho Well-Known Member
    Ralph
    Florence Ky
    2010 MGM Tacoma SR5 Base
    Ivan Stewarts
    maybe a stoooopid question...my truck doesn't have factory remote entry...does that mean there is no receiver in the truck's harness? Or did they just not provide transponder keys? Would like to add keyless stuff if it is still possible...anyone have a few sentences which would clear up my options?
  4. Dec 5, 2018 at 8:34 AM
    #44
    Mugsy19
    Mugsy19 Member
    Mark
    2015 Silver Tacoma TRD Sport Pro
  5. Feb 26, 2019 at 3:26 PM
    #45
    Superman1355
    Superman1355 Well-Known Member
    15 super white DCSB TRD offroad
    i just did this on the oem remote for my 2015. musta tried 10 times and couldnt get it to work.
    i forgot to remove the sticker on the battery :facepalm: so it wasnt making any connection.
    worked first try after that! thanks
  6. Feb 27, 2019 at 8:27 PM
    #46
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    Good info to have
  7. Aug 18, 2020 at 1:21 PM
    #47
    SpyderMan
    SpyderMan Well-Known Member
    Morgan Hill, CA
    05 TRD
    Saved me from the dealership! Thank you!
