Programming Locks to Eliminate the Beep
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cindyb95, Apr 21, 2009.
  1. Apr 21, 2009 at 11:14 AM
    cindyb95
    cindyb95 [OP] New Member
    Kansas
    Tacoma SR5 2WD Manual
    Can anyone explain how to program the remote keyless entry so that the truck does not beep whenever it is locked or unlocked?
    THANK YOU!
  2. Apr 21, 2009 at 11:49 AM
    JPinCowtown
    JPinCowtown Well-Known Member
    Texas
    09' SR5 4x4
    I too, would like to know if this is possible - the lights flashing is OK but I find the beep annoying....
  3. Apr 21, 2009 at 11:50 AM
    chrisrothrock2000
    chrisrothrock2000 Well-Known Member
    Fairfax, VA
    Devil Horn Emblem, Access Bed Cover, Wet Okole Seat Covers, Bed Mat, AFE Dry Drop In Filter, Sock Monkey Decals, Custom Fishing Rod Holder
    I have an 08 and ever since I got it from the dealer it never beeped when I locked or unlocked it with the remote. It just flashes.
  4. Apr 21, 2009 at 12:06 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    It's a 2009 thing.
  5. Apr 21, 2009 at 2:41 PM
    NikonRon
    NikonRon Well-Known Member
    Owensboro,Ky
    2009 Tacoma Access 4x4 TRD O/R Pyrite Mica
    Icons,Dakars, Stubb's Sliders,Four Wheel camper Eagle
    Just reach under the hood and disconnect the chirp module.
  6. Apr 21, 2009 at 4:55 PM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    its a 09 thing and it drove me insane
    if i remember correctly
    sit in the truck with the door open and insert the key
    pull the key out and then reinsert it after 5 seconds and turn to the on position, but do not start
    after 10-15 seconds press any of the buttons on the remote twice, and youll hear a chirp and its done
    take the key out and it should be good to go
  7. Apr 21, 2009 at 5:26 PM
    cindyb95
    Kansas
    Thanks for the replies!
    I tried the key/remote advice and I can't get that to work. The owners manual states "contact your Toyota dealer."
    I'm not sure what the chirp module looks like? (sorry - I'm pretty clueless.....)
  8. Apr 21, 2009 at 5:30 PM
    Austin Taco
    Austin Taco Well-Known Member
    Pflugerville, TX
    08, TRD Sport, double cab, long bed
    It's not an 08 or 09 problem. My 08 did it and turned it off. I can't remember how I did it but I'll post up if I remember.
  9. Apr 21, 2009 at 5:34 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    should be a small black platic thing attached to the rear of the radiator on the drivers side....IIRC
  10. Apr 21, 2009 at 5:38 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    my 08 didn't do it from factory, i had to make it do it myself :) Maybe you have the toyota alaram?
  11. Apr 21, 2009 at 5:50 PM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    Posted in another area:
    1. CUSTOMIZING FUNCTION
    The following items can be customized.
    NOTICE:
    • When the customer requests a change in a function, first make sure that the function can be customized.
    • Record the current settings before customizing.
    • When troubleshooting a function, first make sure that the function is set to the default setting.
    • If the battery is disconnected, the wireless answer-back buzzer will be returned to the default setting.
    Item
    Function
    Default Setting
    Customized Setting
    Wireless remote control
    Operation signal (Buzzer)
    ON
    OFF
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    • The driver side door is closed.
    • The ignition switch is turned off.
    • The key is removed from the ignition cylinder.
    • A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    • The transmitter is operated but the second button pressed is different from the first.
    • Answer-back starts.
    Thanks to beeftaco!!!
    __________________
  12. Apr 21, 2009 at 5:58 PM
    cindyb95
    Kansas
    THANK YOU!!!! The beep is gone!! You are all great!!
  13. Apr 21, 2009 at 7:12 PM
    Lhwebbie
    Lhwebbie His and Hers Tacoma's
    Kansas
    08 TRD Sport
    Glad you got rid of the beep!:)
  14. Apr 21, 2009 at 8:53 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Welcome to TW!! Both of you.
  15. Apr 22, 2009 at 4:48 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    So your 08 now does this? I had read that it was not possible for the 08's to have this option at all. I'm so confused......
