progressive 3 leaf differences
Discussion in 'Suspension' started by hanrock, Mar 16, 2017.
  1. Mar 16, 2017 at 6:04 PM
    hanrock
    hanrock [OP] Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    I am curious which 3 leaf pack is better in terms of ride softer, firmer, weight handling I am assuming there is just a few companies building these. I am looking for about 1.5 lift max. I have deaver add a leaf which gave me 2" lift and rough ride DC LB and vibes i couldn't get rid of I went back to 1.25 tapered block and all is good tried 3*and 2* shim OME cb drop nothing worked thanks in advance.
  2. Mar 16, 2017 at 6:15 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The Icon and wheelers 3 leaf should be comparable(or practically the same).
    YotaDan likes this.
  3. Mar 16, 2017 at 6:17 PM
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    I ran the wheelers 3 leaf pack for about 3 years and loved them. Gave about 1.5" of lift and didn't really stiffen the ride up. We're pretty smooth offroad.
    YotaDan likes this.
  4. Mar 16, 2017 at 6:20 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    drove 4,000 miles to SoCal from SoFlo with the Icons with no issues or complaints butter smooth especially with a little weight from a topper.
    DavesTaco68 likes this.
  5. Mar 16, 2017 at 6:22 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I think they are. I have the ICON 3 leaf, and they look exactly the same. Icon doesn't make leafs (yet) so they are probably just rebranded.
  6. Mar 16, 2017 at 7:55 PM
    busatodd
    busatodd BUSATODD
    whiteland
    2016 limited mgm
    3rd gen 5100 bilstiens set at 0 with ome 888s, LR UCA, 5160 bilstiens in back with icon 3 leaf aal with 1" block. Fuel savage wheel wrapped in nitto ridge grapplers 285/70/17
    I just put the icon 3 leaf in tonight, Did you all put the brake line extender block in, it came with the bilstien 5160s. Also just put 3rd gen billies with ome 888s and LR UCA on. Feels like in running over the rumble strip on side of road at low speed. I'm hoping it's just tire noise from alignment and it will be gone tomorrow after I get aligned.
  7. Mar 16, 2017 at 7:59 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I loved the ride of my Icon aal. Butter describes it well.
  8. Mar 16, 2017 at 8:00 PM
    busatodd
    busatodd BUSATODD
    whiteland
    2016 limited mgm
    Did you just do aal, or did you use a block with aal
  9. Mar 16, 2017 at 8:40 PM
    bullaculla
    Da big big island!
    You can unbolt the lower brake line bracket on the axle, put a 1" spacer under it and then secure it with a longer bolt.
    REDdawn6 likes this.
  10. Mar 17, 2017 at 5:26 AM
    hanrock
    craig
    sask
    Just the leaf.
  11. Mar 17, 2017 at 5:38 AM
    btripptrd
    btripptrd Well-Known Member
    Barrett
    Graham, WA
    06 tacoma trd
    2.5in w/ rancho RS9000s, AAL, ECGS bushing
    The rumble strip noise you are feeling or hearing could be the dreaded needle bearing. You might need to look into replacing it with ECGS bushing, tons of info on TW about this problem. Same thing happened to my truck, but replaced the bushing and all is good.
  12. Mar 17, 2017 at 12:59 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    My Headstrong Off-Road Progressive 3 leaf rode smooth on and off road. Also it helps if you have the upgraded bumpstops. I have the All Pro U-Bolt flip kit with the Wheeler's rear and front bumpstops :thumbsup:
    bullaculla and Tatts521 like this.
  13. Mar 17, 2017 at 2:11 PM
    bullaculla
    Da big big island!
    Yep! I have pretty much the same setup. Mid travel fox all around. Id say it performs well :D
    https://youtu.be/32YCW02wS3o
    Lord Helmet[QUOTED] and Tatts521 like this.
  14. Mar 17, 2017 at 2:37 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    curious too after my pack blew to pieces....fuck toyota
  15. Mar 17, 2017 at 2:44 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
    How much lift total did you guys get from AAL? I'm asking because I have a 1.5" block right now and it needs about 1 more inch to level out. Trying to decide between aal & Dakars right now.
    P.S. I'll be removing the block whichever way I go
  16. Mar 17, 2017 at 2:51 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    The AAL I had was about 1.5 " but it depends on is you have the old 3 leaf pack or the 4 leaf tsb pack. I think you can add the 3 leaf pack 2" one to a 4 leaf and get about 2" but you will have to ask someone
  17. Mar 17, 2017 at 2:53 PM
    Dimestore55
    William
    Richmond, VA
    I have the 4 leaf pack and they look new so I think they were replaced already
  18. Mar 17, 2017 at 2:55 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I would say go for the 2" one then if your looking for 2". I had the 1.5 and the 4 leaf pack and it gets you 1.5" for sure
    Dimestore55[QUOTED] likes this.
  19. Mar 17, 2017 at 2:57 PM
    Dimestore55
    William
    Richmond, VA
    Ok thanks
  20. Mar 17, 2017 at 4:03 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Same snorkel I got :thumbsup:
    bullaculla[QUOTED] likes this.
