Progressive add a leafs
Discussion in 'Suspension' started by tacoma guy, Oct 19, 2014.
  1. Oct 19, 2014 at 3:00 PM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Ok so with all the talk about the stock 2+1 leaf springs breaking and sagging I have a question for you guys. I have 20 thousand miles on mine. They don't look too flat. Question is If I were to install the Icon or the wheelers progressive 3 leaf add a leaf would that prevent my leafs from breaking ? I am thinking of putting on a shell and they tell me its about 180 lbs. and we all know what that would do to the stock springs. Also which of the two is the best , the Icon or wheelers ?
  2. Oct 20, 2014 at 8:51 AM
    tacoma guy
    Joe
    Phoenix Az.
  3. Oct 20, 2014 at 10:03 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Icon AAL is the only way to go, single spring AAL's are terrible. The Icon AAL will give the user 1.5" inches of lift, but are not necessarily designed to support a bunch of extra weight.
    Adding leafs to your pack will help out, but I would recommend using a over load air bag or having a custom pack built to fit your load and driving style.
  4. Oct 20, 2014 at 3:22 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This..
    OP.. I had the Icon pack to try and fix my sagging leafs, and although it was very smooth and helped at the time.. it didnt support weight at all. I since then, have replaced the entire leaf pack with a new 10 leaf progressive pack.. it rides great on road, yet still holds weight very well.
    with adding a shell, having that constant weight, plus whatever else in the bed, i would suggest doing the same.
  5. Oct 20, 2014 at 4:17 PM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah thank you all for your replys . It is very helpful and I kinda figured that I would be better off just replacing the leaf pack . I just wanted to confirm my feelings . I appreciate everyone's option .
