Progressive Leaf Springs?
Discussion in 'Suspension' started by Phantom_X-SP, Apr 30, 2009.
  1. Apr 30, 2009 at 7:16 AM
    Phantom_X-SP
    Phantom_X-SP [OP] Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    While running this morning a random thought zipped through my head...scary I know.
    This is my first vehicle with a leaf suspension so I'm no expert on leaf springs...but I do have a question.
    Are the factory Tacoma leaf springs progressive? I'm assuming they are since they are a multileaf spring as opposed to a monoleaf spring. I figured since the leaf springs are different in length, then the compression rate will differ depending on the force applied to them...thus making them progressive. I could be making a wrong assumption here...does anyone know for sure?...or do I just need to shut up :confused:
    btw this is just a curious thought :D
  2. Apr 30, 2009 at 7:18 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Interesting thought.
    I'm not sure about the first 3 leaves being progressive, but I would say that having the 4th overload leaf qualifies the springs as progressive.
    The overload leaf is a completely different shape and will make it much harder to completely bottom out.
  3. Apr 30, 2009 at 7:23 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Chris knows better...sadly I posted BEFORE he did....OOPS
  4. Apr 30, 2009 at 7:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All leaf spring set ups are a progressive rate.
  5. Apr 30, 2009 at 8:53 AM
    Phantom_X-SP
    High Point, NC
    Thanks Chris...is it progressive due to the overload leaf as stated above or the design of the spring itself? (meaning a monoleaf spring would be progressive as well)
  6. Apr 30, 2009 at 8:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being a multi spring pack, it will be progressive in nature. Single leaf springs can be made "Progressive" if the thickness is changed through out its length (ie, the newer Corvettes have a leaf rear suspension).
  7. Apr 30, 2009 at 8:59 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I think that it is the compounding of the multiple leaves. A single leaf spring would not have a progressive spring rate.
    Edit: Dang it Chris!
  8. Apr 30, 2009 at 9:02 AM
    Phantom_X-SP
    High Point, NC
    Thats what I thought...thanks for clarifying! You are the man! :thumbsup:
