PROJECT ALL TERRAIN
Discussion in '2nd Gen. Builds (2005-2015)' started by hard2kill, Aug 18, 2011.
  1. Jul 29, 2012 at 8:01 AM
    #261
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Get a locker, it helps more than a crawl box IMO. Even though I've seen many people argue the fact that the box helps more than lockers. It really depends on the situation. A box won't help you in mud, nor will a crawl box help you when you have 2 tires off the ground, or 1.
  2. Jul 29, 2012 at 9:54 AM
    #262
    hard2kill
    hard2kill [OP] Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    thanx guys yea im gonna do 4.56's and a rear locker first...not sure if im gonna just get a lock rite or go all out for an arb in the rear since its not my dd any more..
  3. Jul 29, 2012 at 9:55 AM
    #263
    hard2kill
    Rhinebeck NY
  4. Jul 29, 2012 at 11:56 AM
    #264
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That's awful cheap.. Cheap winches worry me. I'm not going all out but I am getting a warn vr1000 with synthetic line
    Thanks for the heads up about the tires.. I'll have to think about it but I'd probably buy 2 more and have 4 new tires and 2 spares.
    Gotta figure out what to do with my current tires..
  5. Jul 29, 2012 at 2:04 PM
    #265
    hard2kill
    Rhinebeck NY
    price is cheap winch is not... :)
    fourwheeler magazine top 10 winch test
    4th Place
    Engo E9000
    Spawned from the former CFO of Mile Marker winches, Engo is a new up-and–coming winch manufacturer with an emphasis quality, value, and customer service. Engo has a full line of recovery winches available from 3,000 to 12,000 pounds, offering both hydraulic and electric-powered versions for regular consumers and military clients. The E9000 model we tested originated in China, but came securely boxed with two plastic straps and plenty of ribbon tape to keep contents secured inside. Additionally, two robust clamshell Styrofoam inserts minimized movement within the parcel. The unit weighed just 49.4 pounds without cable, securing the ultra-lightness award of the all the units we tested. The 5.5hp series-wound motor is offered in both 12- and 24-volt versions. The most noteworthy observation we made during our testing of the E9000 model was how easy the drum free-spooled when the clutch was disengaged. Where some winches required our staff to pull cable from the drum using significant upper body weight, the Engo required just one arm. During our speed and efficiency test, the E9000 took third place, leaving just over 22 feet of rope unspooled. The motor reached a maximum operating temperature of 151 degrees during the pull. During the stall test, the E9000 pulled to 12,000 pounds and stopped sans drama. Once removed from the stall test, the unit continued to work flawlessly in either direction. It’s important to note that this was one of only two winches that survived the stall test unscathed. Considering that it survived our thrashing and can be bought at the very affordable price of just $329.99, we had to award the Engo E9000 as the best value of the group. Info: Engo Industries, 360/642-0079, www.engousa.com
    Engo takes great care in ensuring that the winch and all of its accompanying componentry s
    »The Details
    General
    Model: Engo E9000 (p/n 77-09000)
    Price as tested: $329.99
    Pull rating (lb): 9,000
    Remote: 12-ft hand-held remote switch
    Drive gear: 3-stage planetary
    Gear reduction: 235:1
    Motor (hp): 5.5
    Cable diameter (in): 21⁄64
    Cable length (ft): 92
    Shipping weight (lb): 84
    Battery cables (AWG): 3.5
    No-load line speed (ft/min): 24
    Read more: http://www.fourwheeler.com/techarti...lti_winch_shootout/viewall.html#ixzz2231KOAgj
  6. Jul 29, 2012 at 3:03 PM
    #266
    Supra TT
    Eric
    Indiana
    ARB's are nice... But 2 ARBS and a compressor + Installating of the wiring and hoses are going to cost you close to $2k. (So nice tho...)
    Lockrites will end up being half the price.
  7. Jul 29, 2012 at 6:12 PM
    #267
    JLink
    Josh
    Ocean, NJ
    Ahh.. Thought id read about engo somewhere before. Thanks for sharing that.. Sounds real good.
  8. Jul 29, 2012 at 6:29 PM
    #268
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  9. Jul 29, 2012 at 6:36 PM
    #269
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  10. Jul 31, 2012 at 5:29 PM
    #270
    hard2kill
    Rhinebeck NY
    lockrite just in the rear with the 4.56's and im gonna get them pre-assembled and just send my cores back ...ill do the install myself....should help keep initial cost down....later on down the road i may lock the front i dont feel like snapping cv's to get over something id rather just pull cable if i have too
  11. Jul 31, 2012 at 6:11 PM
    #271
    hard2kill
    Rhinebeck NY
    im not lazy,i dont mind....i been down some tuff shit with no lockers at all an 33's im pretty sure with 35's,gears,rear locker and a new shackle flip ill have some crazy fun
  12. Jul 31, 2012 at 6:25 PM
    #272
    hard2kill
    Rhinebeck NY
    yeah keep it quite bro only a few can go..i have 3 deff right now and you cant really have a group over 6-8 or its way crowded....only thing is it takes like 3hrs to run trail im told and its a pretty long drive for you guys south of me for one short trail..but look damn fun...winch and at least 33's are a MUST ,lockers and 35's required to avoid winch..lol
  13. Aug 1, 2012 at 5:23 PM
    #273
    hard2kill
    Rhinebeck NY
    Shackle flip... Yes please I can't wait !!!!! No better way to make a limited slip work better then to keep the tires on the ground ;)
  14. Aug 1, 2012 at 7:27 PM
    #274
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'd get with Kevin @ ATO before you drink the kool aid on the fabjunkie ones...
    Just my $.02
    I know from having the opportunity to spend some time with you that you truly care about the parts you install - there are some questionable aspects to that "adjustable" design, all of which have been debated to quite an extent.
    I lucked out to get an older unused ATO flip but now Kevin has an even better design - see jandrews build - you may want to take another look at your plans my friend.;)
  15. Aug 2, 2012 at 6:57 PM
    #275
    hard2kill
    Rhinebeck NY
    I have and for the price of a brand new set I couldn't turn it down... I'm gonna play with it get it dialed in and the reinforce it to my likening ;) no worries Ill make it good ;)
  16. Aug 2, 2012 at 8:02 PM
    #276
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Best of luck to you then my friend! :thumbsup:
    BTW trail 37 - the blue on the new side at Rausch - got tamed down a bit. More green now except for the end. :rolleyes:
    Was not the same without you guys.
    The New England guys were cool though.
  17. Aug 2, 2012 at 8:04 PM
    #277
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the south will rise again!!!!!!
  18. Aug 3, 2012 at 4:04 PM
    #278
    hard2kill
    Rhinebeck NY
    lol...i wish i could have made it out there for that meet...
  19. Aug 5, 2012 at 3:55 PM
    #279
    hard2kill
    Rhinebeck NY
    1.75 wheel spacers ????? yes please and thank you...one step closer to clearing 35's ;)
  20. Aug 5, 2012 at 7:34 PM
    #280
    Supra TT
    Eric
    Indiana
    What about clearancing? :D
