PROJECT ALL TERRAIN
Discussion in '2nd Gen. Builds (2005-2015)' started by hard2kill, Aug 18, 2011.
  1. Aug 19, 2012 at 10:23 AM
    #301
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    no need to destroy purdy aftermarket ones. they're actually a very strong wheel too.
  2. Aug 19, 2012 at 10:28 AM
    #302
    hard2kill
    hard2kill [OP] Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    hell ya there strong and very solid....and alloy wheels hold tires much better then steel at low psi..
  3. Aug 19, 2012 at 12:20 PM
    #303
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Subbed, cant wait to see this with 35's.
  4. Aug 19, 2012 at 12:48 PM
    #304
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Why the fatter spacers? :confused:
    Were you hitting somewhere?
  5. Aug 19, 2012 at 7:25 PM
    #305
    hard2kill
    Rhinebeck NY
    Thanx man me too... Got a few more things to get first. It I'm workin on it ;)
  6. Aug 19, 2012 at 7:29 PM
    #306
    hard2kill
    Rhinebeck NY
    I know a fellow member that's runnin stock wheels with the same 315's I'm getting with 1.5in spacers and just barley rubs frame so that extra .25in and a perfect alignment should allow me to clear frame and I'm getting a 1in body lift like ant has so my fender wells should clear after pintch weld cut an weld,can mount chop and fender trim :)
  7. Aug 19, 2012 at 7:55 PM
    #307
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Gotcha... I'm hoping to go that route at a later date but with the 4" backspacing of the wheeler's steelies and 315's...
    Gotta find a DD first. :(
  8. Aug 21, 2012 at 4:42 PM
    #308
    hard2kill
    Rhinebeck NY
    Thanx ant... Won't be bad on bearings my offset wit stock wheels is roughly the same as ur 4in backspacing wheels....the stress load would only be bad if I got an offset wheel ;) ...I gotta get my lca's replaced ASAP then a body lift!!! Hopefully 35's in the fall... Looks like gears will be next yr probly
  9. Aug 30, 2012 at 9:10 AM
    #309
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Happy Birthday old man!
  10. Sep 11, 2012 at 4:31 PM
    #310
    hard2kill
    Rhinebeck NY
    Thanx lil brotha ;)
  11. Sep 13, 2012 at 1:58 PM
    #311
    hard2kill
    Rhinebeck NY
    886's are here along with 1/4in spacer from toytec......install hopefully saturday as long as i can get my lcas and and alignment cams/bolts/tabs bent back straightened and re welded....lol
  12. Sep 13, 2012 at 2:14 PM
    #312
    hard2kill
    Rhinebeck NY
  13. Sep 14, 2012 at 11:09 AM
    #313
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Haven't seen those before..
    I just pulled mine out the other day since its been a year since I greased them last. Came out like a dream. Idk wtf Toyota was thinking when they assembled these without grease...
  14. Sep 14, 2012 at 3:39 PM
    #314
    hard2kill
    Rhinebeck NY
    I just hope I can get mine out... Hopefully 2mro morning I can get wrench time in
  15. Sep 14, 2012 at 4:51 PM
    #315
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i could get my bolts out, but no luck on the sleeve.
  16. Sep 14, 2012 at 9:27 PM
    #316
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    Hell OP, I am looking for some advice on a front spring and coil set up. Since I have gone through most of your thread and seen all the different set ups you have run. I am looking to install my All Pro Apex bumper next week and am concerned with the added weight. I am currently running bilstein 5100’s with off road coils set at 2.5 (MAX). Was wondering what your recommendations are for the added weight (Nitrochargers, OME 885’s or 886’s). Or will I be ok with my current set up. I do some minor offroading (slow Stuff) but mostly drive on the street.
  17. Sep 17, 2012 at 11:50 AM
    #317
    hard2kill
    Rhinebeck NY
    since you have a double cab v6 its already a heavy truck just like mine...with the added weight of the bumper and an ifs skid the stock coils will not handle the weight well ...i lost almost all of my lift height after skid/bumpers up front and offroading easy or hard led too constantly bottoming out....and poor cornering on the street.....if your not gonna add a heavy winch and full skids,roof rack etc like me i recomend OME885 springs on your 5100 set at zero.......if you wheel hard and are gonna get a winch and heavy armor get the 886 right away....i loved my 885 they road amazing on/offroad but im mounting up a 100lbs winch soon and going to 35's so i needed the stiffer springs..
  18. Sep 18, 2012 at 7:29 AM
    #318
    hard2kill
    Rhinebeck NY
    will be bought after i finish lca's/susp/alingment BS...shit aint cheap..on a side note had to use my winch money to buy a suit for my friends wedding :( ........fucking weddings
  19. Sep 18, 2012 at 7:45 AM
    #319
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    open bar?
  20. Sep 18, 2012 at 7:51 AM
    #320
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if it's not an open bar, he didn't buy a suit for a friends wedding......he baught a suit for a wedding.
