Project Basketcase: Another ReSAS story
Discussion in '2nd Gen. Builds (2005-2015)' started by SGTCap, Jul 16, 2016.
  1. Jul 19, 2016 at 8:18 PM
    #61
    SGTCap
    SGTCap [OP] Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    It cleared. But Im gonna do one better. I'm going to bob the bed
  2. Jul 19, 2016 at 8:21 PM
    #62
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  3. Jul 19, 2016 at 8:26 PM
    #63
    Duck_Hunter
    Duck_Hunter Well-Known Member
    Tejas
    2014 Tacoma TRD Off Road Manual
    ATC shell
    :thumbsup:
    scottalot and ChadsPride like this.
  4. Jul 19, 2016 at 8:40 PM
    #64
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Question: as I ain't an extreme off roader,
    What's the purpose of the bumper and the bar being such as it is on the front?
    Rock slider?
  5. Jul 19, 2016 at 8:56 PM
    #65
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    IF it were constructed properly, which this isn't, lets say you're at a big ledge or boulder. You can actually push the "stinger" into an object and let it help lift the front end to get your front tires to contact the object. Also on an extremely steep descent the stinger will hit the ground first pushing the front end up so you don't flip. In most cases, such as this, they serve no purpose other than looking good and giving the driver a reference point of where the front end is. Mine will be coming off and getting replaced with a real bumper from SOS Concepts.
    TacoTRD78, ChamYota, RogueTRD and 4 others like this.
  6. Jul 19, 2016 at 9:02 PM
    #66
    Skyway
    Ande'
    St.Pete
    Cool. I like the idea of maybe cutting it off.
    The explanation is solid!
    God, Save the South!
    Tou got a link to one of your expos?
    What is that? " I don't think I pads speak southern.
  7. Jul 20, 2016 at 3:26 AM
    #67
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    :yes: I was hoping you would do that
    scottalot, ahspurlock and ChadsPride like this.
  8. Jul 20, 2016 at 9:15 AM
    #68
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I haven't posted pictures of it but the frame is missing behind the rear shackels. It's fust got a piece of sheet metal welded in that the rear bumper is then welded to. So I assume that it was bobbed previously. I know the bed is not factory, so I assume thats why. Might as well reBob it though. I'm going to do a flatbedish thing with tool box sides, baja style tire gate (for lack of better description and enough bed space to fit my deployment bag. When I'm done I'll cut the factory bedsides to fit and hange them back on the truck so it looks less flatbed like. YOu'll see. Should be interesting. If I knew how to use solid works I'd make a drawing of it.
    Damn I wish I knew how to use that
  9. Jul 20, 2016 at 9:54 AM
    #69
    Carrionman
    Carrionman Well-Known Member
    James
    Eastern NC
    2013 4x4 v6
    Nice Robert, this should be quite the adventure.
  10. Jul 21, 2016 at 4:33 AM
    #70
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Hobart 140 welder came in yesterday. Pitman arm shipped as well.
    Checking stuff of the list. Getting a step closer every day
  11. Jul 21, 2016 at 4:35 AM
    #71
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
  12. Jul 21, 2016 at 6:21 AM
    #72
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    You going to do the welding? :spy:
  13. Jul 21, 2016 at 9:04 AM
    #73
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Some of it I'm sure. But moving it back and forth to the shop just to lay a couple welds would be a real PITA. So I figured it best to have a welder in the unit with Basketcase to do the smaller stuff at least. The vast majority can be done with the little Hobart 140 I bought. And I should learn to run it myself at least somewhat, especially when I have an experienced welder to teach, critique and correct my fuckups. Can't make Eddy do all my dirty work forever.
  14. Jul 21, 2016 at 9:06 AM
    #74
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I want to learn some welding myself :drevil:
  15. Jul 21, 2016 at 9:07 AM
    #75
    ChadsPride
    Sponsored by TacomaWorld.com
    Same
    scottalot likes this.
  16. Jul 21, 2016 at 10:11 AM
    #76
    tgear.shead
    tgear.shead Well-Known Member
    Could also have been in a wreck. That segment of the frame twists downward when rear-ended. Wreck would also explain non-factory bed.
    And for that matter, if you're going to do a half-assed offroad mod, what better to start with than a wreck you get for cheap?
  17. Jul 21, 2016 at 3:26 PM
    #77
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Thats entirely possible as well.
    I just realised I put this in the Second Gen forum and not the build threads. Why hasn't anyone said anything? I'm supprised the mods didn't move it already.
    ahspurlock, ChadsPride and scottalot like this.
  18. Jul 21, 2016 at 4:56 PM
    #78
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    In to see the progress. Going to be sweet!
    ChadsPride likes this.
  19. Jul 22, 2016 at 8:28 PM
    #79
    Skyway
    Ande'
    St.Pete
    Dangit! I liked it over there...
  20. Jul 23, 2016 at 7:02 AM
    #80
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Everything goes in 2nd Gen
    :laughing:
