Project cold air 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by doodle66, Mar 1, 2010.
  1. Mar 1, 2010 at 7:48 AM
    doodle66
    doodle66 [OP] Texas Taco
    Robert
    central tx.
    03 dbl cab blk
    deck plate mod, cold air scoop, K&N, fog light mod, aux. lights,
    Here are the finished pics. The stock elbow is open right now, i'm trying to move the air through the box for heat transfer, not for induction. Colder air is what i'm looking for. I will measure temps inside the box with it stock, then deckplate, then mine elbow open, then elbow closed. Witch one keeps the air colder ? If i can get enough induction pressure with the elbow closed, then we may have a winner, i kinda doubt it. At highway speed or faster possibly. I want to see how much difference good cold air actually does when its consisant all the time.
  2. Aug 14, 2010 at 5:49 PM
    ccoliver09
    ccoliver09 Member
    California
    00 Tacoma PreRunner
    CB Radio Tow Hitch Fog Light Mod Deck Plate Mod
    What are the results of the experiment?
  3. Aug 14, 2010 at 6:13 PM
    iDigTulsa
    iDigTulsa Well-Known Member
    Luke
    Tulsa, OK
    03 DoubleCab TRD SR5 4x4
    Free Alarm Mod, Grey Wire Mod, Reverse Leaf Spring Helper Mod, Kenwood Deck, Memphis 10'', Yakima Roof Rack, Debadged Sides,Silver Toyota Skid Plate, Injen CIA, 3.5'' Amsoil Dry Filter, 17 x 7.5 Tundra Split Spoke Alloy's
    x2
    Bump:confused:
  4. Aug 14, 2010 at 6:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Good idea, but there are alot of bends in that pipe.
  5. Aug 14, 2010 at 7:57 PM
    doodle66
    Robert
    central tx.
    03 dbl cab blk
    ambient air flows through the box and out the elbow. that is the best way to keep the box cold. engine pulls what it needs from the cold air moving through box. At 35 mph enough air moves through this box to feel like hair dryer on high. i tried with a shop vac hose tied into the box. massive air flow at low speeds. reach down and close the valve i put in and your back to stock if your worried about hard rain at interstate speed.
  6. Aug 14, 2010 at 8:08 PM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    hey you should put a velocity stack on the end of it right up against the K&N for max flow lol
  7. Aug 14, 2010 at 8:10 PM
    TanSR5x4
    William
    Houston TX
    00 Tacoma SR5 4x4
    or what if you put a big block of dry ice in the box too!
    damn i should be an engineer
    lol
  8. Aug 14, 2010 at 8:14 PM
    doodle66
    Robert
    central tx.
    03 dbl cab blk
    it works well so far. i noticed the initial gains with the deckplate mod, not as loud now, but i seem to get much better mileage. throttle response is much better than stock. remember this is a trial thing, i may bend some tubing for a better look, but metal gets much hotter than plastic, and it's not as smooth inside.
