Project: DBL BLK ◇ by ToyRyd
Discussion in 'Solid Axle Suspension' started by ToyRyd04, Jan 2, 2015.
  1. Jun 20, 2020 at 7:01 AM
    #381
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  2. Jun 20, 2020 at 8:49 AM
    #382
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :eek:
    As if this truck wasn’t bad ass enough!
    :popcorn::popcorn::popcorn:
    ToyRyd04[QUOTED][OP] likes this.
  3. Jun 20, 2020 at 9:42 PM
    #383
    ToyRyd04
    ToyRyd04 [OP] Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Update. Bit slow, car lift decided to blow the main hydraulic line while the truck was on it :mad: sketchy but saved to say the least. Napa came through with a 30ft replacement and crimped ends in 15mins.
    20200620_141408.jpg 20200620_141444.jpg 20200620_145151.jpg 20200620_165109.jpg
    HP 3rd set to 11.5° knuckle balls set to 8° of caster.
    20200620_165652.jpg 20200620_185047.jpg 20200620_214551.jpg 20200620_214557.jpg
  4. Jun 23, 2020 at 8:38 AM
    #384
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Updates.
    Got the front diamond almost assembled. Running into a hub/seal/spindle issue when preload is set on the wheel bearing the hub cannot turn at all.
    20200621_103532.jpg 20200621_103539.jpg 20200621_103549.jpg 20200621_142341.jpg 20200621_230505.jpg 20200621_230521.jpg 20200622_001632.jpg 20200622_165258.jpg 20200622_165324.jpg
    slander and Duckfatt like this.
  5. Jun 23, 2020 at 8:59 AM
    #385
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Thanks! :cool:
  6. Jun 24, 2020 at 6:55 AM
    #386
    cynicalrider
    cynicalrider #NFG
    Jersey
    Trucks coming out good Greg. Stoked to see it on the new axles! Do you have a tire size goal for the new setup?
    ToyRyd04[OP] likes this.
  7. Jun 24, 2020 at 7:07 AM
    #387
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Thanks Mike, both new axles ought to change alot of things that will make it easier on and off road.
    Tire size will be the same, actually the Pitbull tires and SCS wheels were in prep for the new axles. (backspacing and tire width) Wider also means into the fenders more so some body chopping is in the future with a new fender flare setup im looking to try out.
    Main changes the axles bring are:
    Strength and width obviously :rofl: , all four corners now use the same spindles, wheel bearings, seals, etc. New pinion angle for HP Ziplocker 3rd (new setup puts the pinion and u joint above the front leaf springs!!), new low profile spring mounts and caster angle and wider shock mounting for stability.
    Under axle clearance, more than both previous housings which would be equal to about being on 39-40s.
    Rear axle will be a big change with strength from full float, disc/P. brakes, RCV shafts, pinion angle, and removing the LSPV in favor of a manual dial.
    slander, avw4x4, Ritchie and 4 others like this.
  8. Jun 24, 2020 at 2:53 PM
    #388
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  9. Jun 24, 2020 at 8:36 PM
    #389
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is center diff clearance about the same?
  10. Jun 25, 2020 at 4:01 AM
    #390
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Easily an inch more clearance on both, more on the front. I'll have to grab a pic inside the inspection hole (aluminum knob cover on both axles) Literally the ring gear is a 1/4" away. Diamond center section is really built as tight as possible to the 3rd.
    jubei likes this.
  11. Jun 25, 2020 at 6:38 AM
    #391
    cynicalrider
    cynicalrider #NFG
    Jersey
    I dig it. Was the rear still the stock width semi float?
  12. Jun 25, 2020 at 6:47 AM
    #392
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Factory rear was unchanged and no wheelspacers.
    Once the front is finished, i'll post pics of building the rear diamond.
    jubei and Ritchie like this.
  13. Jun 25, 2020 at 6:48 AM
    #393
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
  14. Jun 25, 2020 at 6:54 AM
    #394
    cynicalrider
    cynicalrider #NFG
    Jersey
    I'd kill for a full float rear. Fuck the bearing/seal job on these trucks. Though since both are fresh and lasted 200k hope I'm good for a while. Still wish i had FF in case I ever grenaded the diff tho.
    slander and ToyRyd04[QUOTED][OP] like this.
  15. Jun 25, 2020 at 6:56 AM
    #395
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    I know where you can find some prebuilt semi float shafts w/bearings on 26k miles set...:anonymous:
    And yeah being able to pull a shaft or even unlock the whole rear is going to be nice. Also, semi float the trucks weight is a factor as it puts load on the axle shaft. FF all stress is just turning the wheels forward or backward.
    slander likes this.
  16. Jun 25, 2020 at 7:05 AM
    #396
    cynicalrider
    cynicalrider #NFG
    Jersey
    Since I just rebuilt mine I'm not worried, but @avw4x4 might be interested...
    And true, I forgot about that too. Always liked the idea of swapping an elocker fj80 axle underneath the rear.
    slander likes this.
  17. Jun 29, 2020 at 4:04 AM
    #397
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Front axle is bolted on. Still need the HA, skid, drag link and should finally be done with that axle :cool:
    slander, jubei, malburg114 and 4 others like this.
  18. Jul 5, 2020 at 1:51 PM
    #398
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Do it!
  19. Jul 6, 2020 at 4:20 AM
    #399
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    More pics to come, still making progress.
    Ritchie, slander, MY50cal and 4 others like this.
  20. Jul 9, 2020 at 11:43 AM
    #400
    cynicalrider
    cynicalrider #NFG
    Jersey
    Damn you are progressing fast! Are you still running a high ride height? I know you lowered it a little after the incident on J. These axles should stay nice and low I'd assume, they gotta be heavy.
