Projector brands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michael11993, Sep 5, 2012.
  1. Sep 5, 2012 at 3:39 PM
    michael11993
    michael11993 [OP] Well-Known Member
    2006 PreRunner
    Tint 12 in kicker Amp Viper Alarm sytem Dual floater exhaust K&N air filter X-D Series Black Rims
    Whats the best brand of projectors to buy?
  2. Sep 6, 2012 at 1:28 AM
    brianv3ntura
    brianv3ntura Well-Known Member
    Jacksonville FL
    MGM'12 Taco TRD Sport 4x4 DCLB 4.0L 5spd Auto
    Stock for now.
    easy install? fx-r TRS aka theretrofitsource
    better projector,but more work? projectors from an s2k,TL or tsx. TL being the better one out of the group.
  3. Sep 6, 2012 at 1:43 AM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    PM AsianAnt...he's done a ton of projector retrofits...he's probably got some good knowledge on what's the best out there.
    But the real question is...how much are you willing to spend?
  4. Sep 6, 2012 at 1:54 AM
    Rascal737
    Oliver
    Abbotsford, BC
    OP, do a search in the lighting & HID section...there's probably a bunch of stuff in there
  5. Sep 6, 2012 at 5:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Easy install - Morimoto D2S or H1
    Slightly more difficult install but better projector - FX-R
    The S2K is a low beam only projector and low beam to low beam is better than the TL. The LS430 is also an incredible low beam only projector, some would argue that it's better than the S2K.
    If you look into more expensive options or are going for the 'best' light output you can find, the LS460 is most likely going to be the best out there. If takes very extensive modification of the headlight housing to make it work though. Best to have a professional do it for you unless you really know what you're doing.
