Projector Conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Jun 5, 2022.
  1. Jun 5, 2022 at 9:09 AM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Thinking about doing my own projector headlights upgrade to my OEM housings. I keep seeing mixed opinions on light output? My goal is increased light output and a good focused beam. Which kit has the best light output and beam?
  2. Jun 5, 2022 at 9:13 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Definitely want to go with the D2S kit from The Retrofit Source. I’ve had great results with mine!
    jboudreaux1965[OP] likes this.
  3. Jun 5, 2022 at 9:15 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Everything you need is in here. All of the do's and don'ts. Along with info, real world test and comparisons. Crashnburn80 is the guy who host that thread.
    https://www.tacomaworld.com/threads...11-projector-headlights.589465/#post-19689308
    Other usefuls thread by him.
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
  4. Jun 5, 2022 at 9:35 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    FYI the third gen low beam projector was poor imho and NHTSA testing “marginal” compared to traditional low beam lamps such as you have now. I had to upgrade to a high performance halogen bulb (in some of the links above) to make it acceptable.
    Don’t know about the aftermarket projectors.
  5. Jun 19, 2022 at 7:59 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Thank you guys!
  6. Jun 19, 2022 at 8:09 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    This is what I have. Amazing even light that lights up perfectly below the cutoff. Above the cutoff is still dark as hell LOL! So both good and bad. Would I do it again? Probably.
  7. Jun 20, 2022 at 1:58 AM
    ty.s07
    Alabama
    Ha yesss, until you hit the high beam!
