Projector fogs yay or nay?
Discussion in 'Lighting' started by 07TacoRidah, Jan 6, 2012.
  1. Jan 6, 2012 at 2:01 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
  2. Jan 6, 2012 at 2:15 PM
    greenguy3
    greenguy3 BOOM goes the dynamite!
    Ian
    Arkansas
    Dirty A$$ TRD
    Mud and dirt
    Sexy kinda...yay?
  3. Jan 8, 2012 at 5:33 PM
    Dr. Sleep
    Dr. Sleep Well-Known Member
    Shane
    Colorado
    07 DoubleCab SR5 4X4
    I vote nay on doing projectors on fogs period with or without the angel eyes. Main advantage to projects is increased lumens and increased bulb life...neither of which are that important in fog lights. Most people don't use their fogs enough to take advantage of the bulb life..nor do you really need the increased linens over factory fogs
  4. Jan 8, 2012 at 6:54 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You forgot about one of the best features of projector style lighting, beam pattern... I put the Blazer projectors in my fog lights and it's awesome having a bright, wide pattern that low to the ground and the cut off from the projectors means it not blinding oncoming traffic. To me it made better sense to retrofit the fogs vs. the headlights because there are no moving parts to fail with retrofitting the fogs.
    OP, if you can do without the angel eyes, check out theretrofitsource.com. They have a set of projectors called the Blazer. A few of us have retrofitted them into the factory fog light housing and they have pretty great light output.
  5. Jan 12, 2012 at 6:28 AM
    07TacoRidah
    what size are the OE fog lights?
