Projector headlight question no. 23876428
Discussion in 'Lighting' started by mmadej87, Oct 11, 2010.
  1. Oct 11, 2010 at 9:41 PM
    mmadej87
    mmadej87 [OP] Mayday
    NMB, FL
    98 Xcab Prerunner
    ive been looking at getting the projector headlights for my taco
    but i dont really like the ones that im finding on ebay/this site
    does anybody know of any that doesnt have all the LEDs or the halos on it? im looking for something simple, kinda like the retrofit headlights but i dont have the money to buy a set, or the tools to DIY..
    anybody have any suggestions?
  2. Oct 11, 2010 at 9:52 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Morimoto Minis.
  3. Oct 11, 2010 at 10:13 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    not sure if im looking at the correct site...but these are for a retrofit or do they make complete headlight sets?
  4. Oct 12, 2010 at 12:37 AM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
    Morimoto Minis D2s from the retrofit source. If you can do the BHLM, the it'll be a walk in the park.
  5. Oct 12, 2010 at 8:08 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    +2
    d2s or h1. either one will be 10000000 times better than a drop in kit. in fact, maybe someone will post what kind of light output they have with these drop in kits so we can compare them to an actual hid projector retro. night and day difference
    you get what you pay for. cheap=cheap
  6. Oct 12, 2010 at 1:26 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    yea, only those projectors on theretrofitsource.com will give you a good output. all those on ebay and the like will give you TERRIBLE output!!
    those morimoto mini's are as easy as swapping in a bulb adn doing a BHLM. if you can do that, you can install them...
  7. Oct 12, 2010 at 5:28 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    so these morimotos dont require any cutting? ive seen the write ups on here and they seem pretty complicated, not to mention i dont have a dremel (and dont feel like buying one for just one job)
  8. Oct 12, 2010 at 5:35 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    nope, no cutting... the projector has a H4 bulb base, but uses D2 based bulbs. there are a few writeups here and im sure there are a ton more on google...
    EDIT: i was wrong, the mini's are bi-xenon...
  9. Oct 12, 2010 at 5:40 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    dont really care about high beams, never use them since i have 55w 5ks HID
  10. Oct 12, 2010 at 5:41 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    but thanks a ton for the info! im gonna look into these!
  11. Oct 12, 2010 at 5:43 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    np, but FYI, you will need new bulbs (i would suggest OEM ballasts at the same time.) as your kit is H4 based and the projectors require bulbs that are D2 based.
  12. Oct 12, 2010 at 5:54 PM
    IamTacO
    adam
    QC az
    you will still have high beams. the morimoto mini's are bi-xenons. i have the hi/low function
  13. Oct 12, 2010 at 5:56 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    well i have an HID kit already from DDM tuning, which still allow me high/low beams, will these fit?
  14. Oct 12, 2010 at 5:58 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    oh, i understand now, not sure if want to do that now...dont want to buy a WHOLE set up, pockets are pretty shallow at the moment
    also, why wouldnt i just keep my ballasts? is there a big difference between the DDM and the OEMs?
  15. Oct 12, 2010 at 5:58 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ well, your going to need new bulbs no matter what (i have a used set of phillips D2S bulbs if you want them for $50 shipped) and a wire harness ($25) at least. i would highly suggest a set of OEM ballasts (i also have a set of matsushitas or densos i'll let go for $100 shipped/pair) at the same time...
    new ballasts b/c your going to have to get a D2 adapter anyways, and i've heard of so many of those ballasts failing...
    you need a new harness and bulbs anyways, so might as well just sell your kit as complete and get the new stuff. by the time you do this, you will be ahead than if you tried to salvage all that crap for your new setup.
    quality HID setups arent cheap...were not in the $50 kit range when youre trying to do it right w/ projectors.
  16. Oct 12, 2010 at 6:01 PM
    IamTacO
    adam
    QC az
    if your hid kit is an h4, then none of your current components will work with either the d2s or the h1 projectors mentioned above. they both use different style of bulb. you would have to scrap all of that stuff and get a whole new setup. which is actually a good thing. please search for DDM and its sooo hit or miss with their products. even though the have life time warranty, you will be dissappointed in the long run
  17. Oct 12, 2010 at 6:17 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    k, so let me get the pricing right here...
    if i were to buy the set up from you, bulbs/ballast/harness, im looking at 175, then the retrofit projectors are around 120...
    so total price im looking at 295
    that would be all i need? or is there more?
  18. Oct 12, 2010 at 6:27 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i have used D2S ballasts/bulbs that you would get for $150 shipped from me. (phillips bulbs and matsushita (OEM nissan) or denso (OEM toyota) ballasts)
    you would still need the projectors and harness from TRS for $145 plus shipping. you would most likely also want a shroud for the projectors from TRS, so whatever that would be.
    thats all you need...projectors, shrouds, bulbs, ballasts, harness.
  19. Oct 12, 2010 at 6:31 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    thanks for all your help, but i think ill hold off on the retrofit for now..
    would rather put that 300 or so dollars towards something else for the taco (lights work and im content with them)
    maybe ill wait for the ddms to go out then look into that... :)
