Projector headlights on ebay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Calamity_taco, Apr 11, 2017.
  1. Apr 11, 2017 at 9:29 PM
    Calamity_taco
    Calamity_taco [OP] your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 97 & 98 EK, 23 Klx300R, 2022 tracer 9 gt
    just a couple of things tbh
    ChadsPride likes this.
  2. Apr 11, 2017 at 9:34 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    well those look cool
  3. Apr 11, 2017 at 9:39 PM
    lesterb315
    lesterb315 Well-Known Member
    Lester
    SoCal
    2012 DCSB Off-Road
    Don't have any experience whatsoever with these, but from what I've seen on this site in regards to aftermarket headlights, all of these or specifically the "spyder" brands end up have worse light output than stock, or moisture starts getting inside. Most people that upgrade to projector headlights go through the whole "proper" process, and they're definitely not cheap. Just my 2 cents.
  4. Apr 11, 2017 at 9:47 PM
    Calamity_taco
    Jacob
    I understand that people get the crazy expensive ones but none of them look like that they are all very the same I thought these were neat but I know nothing about them to fully jump on them
  5. Apr 11, 2017 at 10:15 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They list the bulb as H9. That is a single filament bulb, without the dual filament H4 your will loose either high beam or low beam so the headlights will likely not have high beam at all. Combine that with almost always no-name ebay lights having poor beam pattern, reduced output, and leaking lenses. Edit: I should also add the H9 has a short life span compared to the H4.
  6. Apr 12, 2017 at 1:29 AM
    Calamity_taco
    Jacob
    It says it has high and low beam plus it's not a no brand it's dtmoto
  7. Apr 12, 2017 at 3:17 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Same light is under a different name on Amazon for less money
  8. Apr 12, 2017 at 3:42 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Willing to bet they are junk
  9. Apr 12, 2017 at 4:50 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    They look really cool like the Tundra ones. I'd be tempted to get a pair and then swap out the crap spyder/eBay projector components for some Retrofit source stuff! And then swap out the fiber optic LEDs for Amber, would look real awesome!
    I like these way better than the other 2012+ ones with the fiber optics on the top and bottom.
    Then remove the junk sealant and get some quality butyl. Would probably be good to go after that.
  10. Apr 12, 2017 at 5:10 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    Well, I ordered a set of these a few days's ago, I ordered the Spyder Projector Lenses, waiting for them to arrive. I will give my input once I get my hands on them and post detailed pictures when I can. At this point, it's only money$$$
    jpereira2 likes this.
  11. Apr 12, 2017 at 5:14 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    That is a lot of money for cool accent light but poor headlight performance
    Tylandus and ChadsPride like this.
  12. Apr 12, 2017 at 5:15 AM
    JdevTac
    Josh
    GA/WA
    2nd gen
    My bet is they will be "ok". You'll probably want to reseal them either preemptively or the second you see moisture.
    I think the newer spyder/eBay stuff is decent. At least compared to the output shots from all the older stuff they put out that had absolutely horrendous light patterns. And that's why they get such a bad wrap. Light output used to be absolute garbage and they leaked like a MF.
    Worst case scenario you can retrofit some better components in.
  13. Apr 12, 2017 at 5:17 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  14. Apr 12, 2017 at 5:21 AM
    gmann1972
    Greg
    Rhode Island
    I will definitely be resealing them before I do the initial install, and give a thorough inspection of the components. I'll let everyone know what I think. I don't mind being the Guinea Pig...lol
    Coot83, GHOST SHIP, jpereira2 and 2 others like this.
  15. Apr 12, 2017 at 6:36 AM
    Calamity_taco
    Jacob
    lol I agree it's a lot of money for a icy light but nobody makes them like that lol that's why I like them so much
  16. Apr 12, 2017 at 6:59 AM
    LSC15
    Logan
    2008 TRD D-Cab
    You can build retros and put an uberflex type strip like that around the bezel/bowl opening and actually have it act as turn signal
  17. Apr 12, 2017 at 7:05 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Could you put H4 bulbs in these or is it a different fitting?
  18. Apr 12, 2017 at 7:06 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I have similar motoz/spyder headlights and the light output with some morimoto HID lights was still WORSE than stock halogen lights. This is because the projector they use in these is utter shit. If you plan to retro, then I say go for it. I wanted a different look from everyone else, and was prepared to retro if I needed to. I know my lights are different, but I would bet money the projectors have similar output as mine had. If you are interested in what is required to get things right, I got a build thread of my retro fit in my sig. I did seal them after the projector install, which was not catalogued in my tutorial unfortunately.
    GHOST SHIP likes this.
  19. Apr 12, 2017 at 7:07 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Nope, H9 should be the only compatible one to use with the high/low option.
    Minny Taco[QUOTED] likes this.
  20. Apr 12, 2017 at 7:29 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It says in multiple places H9. H9 cannot support high and low beam in a single projector, it does not have 2 filaments like the H4. That bulb is used in a standalone high beam lens. So the ad contradicts itself as it cannot have H9 in a single projector and support high/low in a single projector lens. I'm betting it does not support high beam despite what the ad claims.
