Projectors????
Discussion in 'Lighting' started by krisjw101, Mar 10, 2010.
  1. Mar 10, 2010 at 9:39 PM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    I am interested to get a set of projector style head lights. Does anybody have any recommendations on a good quality pair?
  2. Mar 10, 2010 at 9:43 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ^ whatever deal you can find on ebay for oem d2s projectors is good
  3. Mar 10, 2010 at 9:47 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Ok I will check it out. Do they make anything that you swap out the original head light assembly and can bolt in a new pair that are projectors. and still use the factory wires
  4. Mar 10, 2010 at 9:50 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ they sell direct replacement projector headlights on ebay but I would just do a projector retrofit myself. There are no direct replacement bolt on projectors tho, you need to cut into ur headlight housing and custom attach the projectors.
  5. Mar 10, 2010 at 9:51 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  6. Aug 11, 2010 at 2:38 PM
    The Philosophizer
    The Philosophizer Well-Known Member
    Alex
    South Bay
    10 Tacoma
    nothing yet!
  7. Aug 11, 2010 at 2:48 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    apart from not looking too great at all, they still use a halogen bulb as your hi-beams and flash, which means if u flash to pass or use your high beams while offroading, they will only be the halogen bulbs emitting light, your HIDs will only act has low beams.
    A D2s projector uses one HID bulb for both low and high beam. A shutter shield off the beam during low beam use, and when u flash or turn on the high beams, the shutters and unleashes the whole beam. Much better IMO
  8. Aug 11, 2010 at 5:39 PM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    unless you do a complete hid projector retro, any other projector will not be good. those ebay projectors are typically based on a halogen bulb. putting hid's in them will never be the same.
  9. Aug 11, 2010 at 5:43 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Don't mean to thread jack but the OP might be interested in the answer to this also. I looked for a little while for projectors but it seemed a lot of them don't even have an option for high beams? Is this common?
  10. Aug 11, 2010 at 8:39 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    None of them are good quality. Material is very cheap.
    To others, there is nothing wrong with a halogen-based projector. What do you think they used before HIDs? And all of the eBay projector headlights come with high beams.
  11. Aug 14, 2010 at 4:28 PM
    The Philosophizer
    Alex
    South Bay
    10 Tacoma
    nothing yet!
    ok its 430 pm right now and i just finished installing the headlights.
    it went pretty smoothly, the first headlight gave me a little bit of trouble but after that it was smooth sailing.
    im going to check out the quality of the light emission once it gets dark over here, but ill keep you posted.
    they look badass though haha
  12. Aug 24, 2010 at 10:45 PM
    r4e
    r4e Well-Known Member
    Orange County
    Prerunner
    any projectors for 2001-2004? :confused:
  13. Aug 25, 2010 at 12:04 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    well?. are they bright or not?. I have a set coming and was wondering the same thing.
  14. Aug 25, 2010 at 6:43 AM
    IamTacO
    adam
    QC az
    i'm gonna guess that they weren't a super big jump from the stock lights. the vast majority of the ebay type lights do not have very good optics. so the light output will be sub par due to the poor choice in halogen projectors being used. putting hids in them would not be recommended
  15. Aug 25, 2010 at 9:30 AM
    The Philosophizer
    Alex
    South Bay
    10 Tacoma
    nothing yet!
    yes, they are. i'll post pictures tonight. im going to have to do it with my cell phone though so sorry in advance if its low quality.
  16. Nov 7, 2010 at 3:22 PM
    captcrackerhead
    captcrackerhead Well-Known Member
    WV
    '11 DoubleCab LB
  17. Nov 7, 2010 at 3:34 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    The morimoto minis are a fairly simple install with no cutting and very little work required
  18. Nov 7, 2010 at 3:34 PM
    cummins6speed
    From what I have heard the light pattern of the ebay projector headlights doesn't work well with HID's and light output is worse than stock
  19. Nov 7, 2010 at 3:46 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
