Proof Of Frame Flex/Steel Plate Bumper/Rubbing Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Oct 14, 2012.
  1. Oct 14, 2012 at 10:10 PM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    First photo is my truck in the classic pose and the following two fender flare shots are showing what my wings look like. You'll notice a difference in gap and that is (I'm assuming) due to frame flex. The following two photos are how it normally sits. It normally pushes just a tiny little bit on the flares but not too much. Any real concern I should have with the fender flare issue? Anyone else ever notice frame flex like this?
    ImageUploadedByTapatalk1350277647.859767.jpgImageUploadedByTapatalk1350277662.703927.jpgImageUploadedByTapatalk1350277676.384776.jpgImageUploadedByTapatalk1350277692.882770.jpgImageUploadedByTapatalk1350277705.565096.jpg
  2. Oct 14, 2012 at 10:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You might want to shim down your bumper a bit
  3. Oct 14, 2012 at 10:16 PM
    jeremy_283
    It's as far down as it'll go.
    Edit* well if it operates like a pivot there are the stock aluminum crush locations where it mounts then the one location at the bottom of the frame rails. I could add shims at the bottom of the frame rails and that'll pivot the wings down (maybe) but then when I tighten the 3 bolts on the crush locations the may bend to accept the adjustment? That's all I can think of.
  4. Oct 15, 2012 at 3:28 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    You may end up breaking a clip or two on the flair from that. Mine did anyways. Then I adjusted it after, go figure.
  5. Oct 15, 2012 at 4:08 AM
    Namyo
    Namyo -
  6. Oct 15, 2012 at 5:40 AM
    jeremy_283
    I mounted it flush to the stock bumper mounts then adjusted my plates on the bumper to sit even on the bar where the stock tow hook are mounted. If I adjust that first then tighten down the stock bumper mount nuts to 30 ft.lbs. or whatever then wont it bend the mounting location on the truck frame? That was my concern.
  7. Oct 15, 2012 at 9:50 AM
    DueNorth
    PM just sent. Thats how i adjusted my bumper tho. Never noticed anything that was tweaked or bent tho.
