Propeller Shaft, How to Torque
Discussion in 'Technical Chat' started by SC4333, Feb 19, 2009.
  1. Feb 19, 2009 at 1:38 PM
    SC4333
    SC4333 [OP] Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Today while performing the 15K service, I realized there was going to be an issue when it came time to re-torque the Propeller Shaft (drive shaft) to factory specifications. The issue at hand was being able to properly torque the propeller shaft at the rear differential without using an extension and 3/8 universal joint.
    I thought over the problem for a few minutes and came up with an idea. I decided to use a Motion Pro torque wrench adapter (14&12mm) that I had from a previous project. The wrench simply connects to your 3/8 drive torque wrench and creates a 3 inch extension of the torque wrench. This is VERY useful in tight situations, where getting a socket in place is just not possible. Now I do realize that it would more then likely be possible to access the fasteners from the front of the flange, but this would require an extension and probably a universal joint adapter which would effect your torque readings. Fasteners should always be tightened from the 'nut' end rather than the bolt head when applicable.
    Bellow are a few pictures I snapped to depict the process. There is some simple math involved with calculating the torque specifications that are dependent on the length of your torque wrench and the desired final torque output. Anyone who graduated High School could easily pull this off.
    If anyone is interested the torque wrench adapter can be purchased direct from Motion Pro for $14.50, and comes with plenty of clearly stated instructions.
    Adapter and Torque Wrench (adapter must be used in a parallel position to the torque wrench)
    Adapter and Instructions
    Setup In-Use
    Torque Universal Joint Flange Yoke to 65 ft.lbs.
    lo2hi likes this.
  2. Mar 8, 2013 at 9:38 PM
    dgtacoma
    dgtacoma Member
    dg
    norcal- bay area
    08 longbed pre
    debadged billet grill
    you must ride dirt bikes. motion pro is a tool company for motorcycles. rode with the owner on a few rides. great company.
  3. Mar 9, 2013 at 7:04 AM
    BamaToy1997
    Bill
    Navarre, FL
    Good write up. You might want to mention that if you ARE going to use a torque extension, that there is a formula that must be followed to adjust for the additional length that this adapter adds.
  4. Mar 9, 2013 at 7:07 AM
    scocar
    scocar hypotenoper
    Holy thread resurrection.
    I got a couple of Cornwell extenders for my suspension swapout (main eye bolt right next to the gas tank, and also the three top nuts at the top of the coils) and because of the propeller shaft torquing requirement.
    I found this online calculator for determining how to adjust the torque to account for the additional length (moments) of the extension.
    http://www.freeinfostuff.com/TorqueExtension/TorqueExtension.htm
    Karminski, Dirk Diggler and Biscuits like this.
