Proper gear oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by My02tacoma, Jun 16, 2024.
  1. Jun 16, 2024 at 7:21 AM
    My02tacoma
    My02tacoma [OP] Member
    Green Bay, Wisconsin
    Love my 02 Tacoma V6 3.4 4WD 2dr 4.1.1 gear ratio
    Put on after market Black Rhino wheels, put on Cooper tires, added Automatic Start and Tunnel cover so far…
    I need to add differential gear oil to my 02Tacoma V6 4wd 3.4 2door X-cab 4.1.1 ratio and I’m not sure which one to buy. Please advise me!
    Thank you,
    Harleychic
  2. Jun 16, 2024 at 7:29 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Any good GL5 75w90. Personally I use Valvoline in the little baggies. Makes filling up very easy.
    CS_AR and captrussia253 like this.
  3. Jun 16, 2024 at 7:54 AM
    My02tacoma
    Hey! Thank you! I appreciate your help:)
    Nano909 likes this.
  4. Jun 16, 2024 at 8:05 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    HC,
    East Coast Gear Supply (ECGS) is one of, if not the best differential builder in the US. The owner's very educated opinion on gear oils is worth reading: ECGS Gear Oil Recommendation (eastcoastgearsupply.com) If you have not changed your gear oil recently, this would be a good opportunity.
    ridefreak and Black97v6MT like this.
  5. Jun 16, 2024 at 8:15 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    • Temp Reference Chart – oil change frequency
    o 170 Deg - 100,000 Miles
    o 200 Deg - 50,000 Miles
    o 220 Deg - 25,000 Miles
    o 240 Deg - 12,000 Miles
    o 260 Deg - 5,000 Miles
    o 260-300 Deg – 500-1000 Miles until Temp is controlled
    stop on the side of the road or rest area during or after long journey
    pop the fill plug
    stick in a thermometer?
    take the differential temperature
  6. Jun 16, 2024 at 8:17 AM
    My02tacoma
    Leid…thank you for your response and suggestion. I certainly will check it out! I hv2 replace my passenger rear seal as it is leaking. I probably will or should replace both seals. Thought I’d add some oil to bide a little time before I can get it fixed before I totally lose my back brakes and cause more problems…
    leid likes this.
  7. Jun 16, 2024 at 8:22 AM
    My02tacoma
    Black97v6MT,
    Thanks for your informative information! Interesting! Thank you!
    Black97v6MT likes this.
  8. Jun 16, 2024 at 8:29 AM
    Rocket86
    Rocket86 Well-Known Member
    When you say “add” gear oil? You should drain it and replace all new gear oil.
  9. Jun 16, 2024 at 8:33 AM
    Rocket86
    My02tacoma[OP] likes this.
  10. Jun 16, 2024 at 8:58 AM
    Black97v6MT
    iMA0
    tacoLand USA
    i would definitely like to know what temps that rear diff is running under certain conditions
    might have to change it MORE frequently than the normal interval suggestions are
  11. Jun 16, 2024 at 9:09 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    75W90 for standard usage
    85W140 if you do a lot of towing/rock crawling
    any brand is fine the differentials aren't picky
    My02tacoma[OP] and b_r_o like this.
  12. Jun 16, 2024 at 9:24 AM
    My02tacoma
    So I just purchased 3 quarts of this oil and I’ll make sure to drain it first before adding it. I never changed or added gear oil before so I’ll have to utube it lol
    Thanks for everyone’s help and advice
    leid likes this.
  13. Jun 16, 2024 at 9:26 AM
    Black97v6MT
    iMA0
    tacoLand USA
    MAKE SURE that fill plug comes out FIRST before EVER touching drain plug
  14. Jun 16, 2024 at 9:39 AM
    My02tacoma
    leid likes this.
  15. Jun 16, 2024 at 9:56 AM
    Wulf
    rock raisin
    that will be just fine
  16. Jun 16, 2024 at 10:04 AM
    leid
    Brandon, MS
    Very good choice. That Lucas 85W-140 dino gear oil is the ECGS recommended gear oil that I have been running in my front diff./rear diff./R100 Tcase. It is very inexpensive and widely available. Summit Racing sells 1 gal jugs for a very low price with free shipping over $110 or so. I ran the expensive synthetics for over a decade but switched to the Lucas dino gear oil after reading ECGS's opinion. The only real difference I have noticed is that my wallet has stayed a good bit thicker.
  17. Jun 16, 2024 at 10:41 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Down here in the Houston area, the performance dif re-builder guru's at Pyle Bros says dino oil only for diff's is the only way to go.
  18. Jun 16, 2024 at 12:09 PM
    leid
    Brandon, MS
    I lived in Kingwood TX for 16 years while working for CAL then UAL and did rescue/recovery with my '97 V6 Taco 4x4 after the flooding from Hurricane Harvey. The Taco loaded with gas, Stihl chainsaws, logging chains, and a Glock & M4 truck gun to deal with the POS thieves all came in quite handy. A week or so later, I developed typhus for my trouble. Almost lost my 20/20 eyesight. The Kingwood NAPA store carried Amsoil gear oil which was pretty good stuff. But you dreaded changing all the gear oils not just because of the labor involved but because of the expense. I can't tell a bit of difference using Lucas dino gear oil and it does not cost a small fortune.
  19. Jun 16, 2024 at 12:24 PM
    Black97v6MT
    iMA0
    tacoLand USA
    I am thinking that the change frequency needs to be dialed down on my rig to 12k miles
    It was a bit on the watery last time I drained it in october and put some Valvoline 75w90 in there
    Too many consistent highway miles heated it up too much?
    I wish to not have any differential gear issues ever!
    ...Was going to buy amsoil severe but now the Lucas has me all intrigued
    And is it safe to actually put 140 in there during the summer months?
  20. Jun 16, 2024 at 12:40 PM
    leid
    Brandon, MS
    Amsoil Severe was some very good stuff. I still have some to use up. But Lucas 85W-140 dino gear oil is what the diff. experts are telling us to run. Just change it more frequently, which is no problem here as I must change all the gear oils out at least once a year to keep water contamination at bay. Even with all the breathers well extended, moisture will exploit any opportunity to get in.
