Proper headlight upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 29, 2015.
  1. Dec 29, 2015 at 7:48 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Yesterday I performed the ultimate headlight upgrade and am nothing but happy with it.
    Results:
    Before
    After
    Both pictures were taken at the same time of night one day apart on the same road at the same spot. This is with hi-beams. The difference is amazing great coverage and great color.
    If that's not convincing I don't know what is. I was torn between doing a proper HID retrofit and this and decided on this. For about $150 you get headlights that are 2x as bright as stock and a bit "whiter" in color. I'd say the color is around 5000k (correct me if I'm wrong). Install was a piece of cake. The hardest thing was finding out where to mount the relays and fuse. Otherwise I had no problems. I ran a good portion of the wire in front of the radiator which is where the stock harness is (a bit worried about the heat but the harness was rated at about 210 C or F can't remember but it seemed fine considering that's where the stock harness is). Don't forget 1st gens are ground switched so get the ground switched harness.
    Anyways, if you want brighter headlights and don't want to retrofit with projectors and HIDs upgrade to these Osram bulbs. If you're wondering about the whole not legal for highway use thing it just means that since they are over a certain wattage the DOT doesn't approve them, but when put in stock housings in a Tacoma they just look like other modern headlights.
    Credit goes to crashnburn80 for the original idea.
    Jimmyrace, joe25rs, Ngneer and 11 others like this.
  2. Dec 29, 2015 at 5:49 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    I might have to give this a whirl. I put in a set of the Osram 70/65W bulbs but they seem to be close to what the OEM bulbs are. Perhaps utilizing the wiring harness with relays will boost the 70/65 bulbs without having to step upto the 85W bulbs.
    Thanks for the link, much appreciated Amigo!
  3. Dec 29, 2015 at 6:20 PM
    goldentaco03
    Liam
    NJ
    I'm not sure how much of a difference the harness makes. When I have time I'll unwire it and hook up these new bulbs with the stock harness and see how they look.
  4. Dec 29, 2015 at 6:36 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I'll have to say goldentaco03, that really is a tempting upgrade. I wonder if the low beams would be affected at all. I admit, I didn't take time to read the link,
    but I will.
  5. Dec 29, 2015 at 6:55 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Would these melt the stock wiring harness if you just plugged them into the old bulb's place? I'd really like the try them but suck at anything electronics so I'm unsure about attempting this endeavor.
  6. Dec 29, 2015 at 10:03 PM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Give in the chance I would of done this over my current retro fit source hids, I've been uderly unimpressed with the retrofits.
  7. Dec 30, 2015 at 4:11 AM
    Tinmann
    NorCal
    I think you'd run a huge risk of melting the wiring harness if you ran the 85W bulbs, that's one reason for the relays and heavier harness. I have had no problems running the 70W bulbs without the relay harness. But as I mentioned before, I really see no advantage with them over the OEM bulbs.
    burntkat and Norton like this.
  8. Dec 30, 2015 at 4:24 AM
    goldentaco03
    Liam
    NJ
    I think that extra 10w really makes a difference. Plus you're driving them right from the battery.
    Ngneer, burntkat and Norton like this.
  9. Dec 30, 2015 at 4:25 AM
    goldentaco03
    Liam
    NJ
    Low beams are much brighter. Wish I took a picture.
    QMEDJoe likes this.
  10. Dec 30, 2015 at 4:26 AM
    goldentaco03
    Liam
    NJ
    It is plug and play if you can change a headlight and unscrew your battery terminals then you can do this.
  11. Dec 30, 2015 at 4:27 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Nice!!
  12. Dec 30, 2015 at 7:05 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Much better!! Which harness # & bulb# did you use?
  13. Dec 30, 2015 at 7:23 AM
    goldentaco03
    Liam
    NJ
    H4 bulb and harness
    HL28200S harness
    80/85w bulbs
  14. Dec 30, 2015 at 7:36 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    Any pictures of your wiring? I'm a little hesitant to wire these straight to the battery as I've already got accessories running off of it.
  15. Dec 30, 2015 at 8:09 AM
    goldentaco03
    Liam
    NJ
    Yeh I'll take some later. It's not that bad.
  16. Dec 30, 2015 at 9:43 AM
    MindFork
    MindFork Active Member
    PNW
    99 Xcab V6 4x4 TRD
    Really? What bulbs did you go with?
    1rider likes this.
  17. Dec 30, 2015 at 10:49 AM
    amkaos
    amkaos Well-Known Member
    Do you have to take off the grill etc to do this?
  18. Dec 30, 2015 at 11:34 AM
    mtnkid85
    MT
    1999 TRD Taco
    35s, Locked, blown
    35W D2S 3Five 4300K.
    Rambo MARINE Recon likes this.
  19. Dec 30, 2015 at 2:05 PM
    goldentaco03
    Liam
    NJ
    Nope not in a first gen.
  20. Dec 30, 2015 at 2:06 PM
    goldentaco03
    Liam
    NJ
    True but if you read crashnburn80s original build thread he gives a few reason for why not to get hids. Different strokes for different folks I guess.
    Jimmyrace and Norton like this.
