Proper headlight upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 29, 2015.
  1. Nov 6, 2020 at 9:14 PM
    #201
    Akl406
    Akl406 Well-Known Member
    Montana
    97 Toyota Tacoma Black 3.4 V6 5VZE MT
    I feel like I have been living in the dark until now. All I can say is WOW! When I first turned on my lights I felt like a little kid and was giggling all the way home.
    crashnburn80 likes this.
  2. Nov 8, 2020 at 5:24 PM
    #202
    Boujee
    Boujee Member
    Tripp
    2003 black tacoma
    None
    Hey I’m trying to find a way to get more light as I can’t see when driving at night. I’m gonna get some led pods for a little more light but I want to get some new headlights that will give more light than I have now without getting a new housing. Anybody have suggestions for a 03 Tacoma? I’m hoping for some leds if possible.
    Jaymart likes this.
  3. Jan 14, 2021 at 6:26 PM
    #203
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Just saw this now, sorry for the delayed response. Look at the original post here and @crashnburn80 thread. Lot of info. You can run slightly higher wattage bulbs and getter better output, add the harness and you’ll be in even better shape. I eventually added two hella 700s to supplement high beams because I do a lot of back road driving with a lot of deer. Gotta be careful using those hella floods on highway or around cops cause they’ll get you for it if they want to
  4. Jan 17, 2021 at 12:03 PM
    #204
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    So, I was PM-ing with a couple members about this but figured I'd post here to keep as much info available to others as possible on the thread. I should note that I am definitely far from an automotive electrical expert. I know just enough to be a danger to myself and others...ha ha. Anyway, so as described in goldentaco03's and crashnburn80's write ups, I tested the voltage of the headlight plug. The left side (outer most) vertical terminal had 0 VDC. Just to be thorough I tested in inner vertical terminal if the drivers side plug and also got 0 VDC. I tested the top, horizontal terminal and got 12+ VDC. I'm not sure if it matters to this test or the upgrade but I had previously cut the white w/green line DRL wire under the dash to disable the DRLs
    So it seems I have conventionally switched headlights. Has everyone with a US Tacoma with headlight DRLs turned out to have conventional switching?
  5. Jan 17, 2021 at 12:34 PM
    #205
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    It is not 100% "conventional" switching. The on-off is also ground switching. DRL Relay No4 acts to turn on and off headlights.
    When the engine is running the Dimmer Relay provides 12V to high beam filament and common is connected to the open DRL Relay No4 (the relay is open, so no current is running through the high beam filament).
    When the headlights are turned to low beam position the Dimmer Relay provides 12V to low beam filament and common is grounded via now closed DRL Relay No4.
    When headlight are switched to high beam position the Dimmer Relay provides 12V to high beam filament and common is grounded via now closed DRL Relay No4.
    So with DRL disabled headlights are switched by relays on both positive and negative sides.
  6. Jan 17, 2021 at 4:04 PM
    #206
    goldentaco03
    Liam
    NJ
    The general consensus in this thread seemed to be that if you have true DRLs you are gonna need the conventionally switched harness. If you don’t have DRLs then ground switched it is. I didn’t know 2001s had DRLs as an option I thought that was a mid year change?
  7. Jan 17, 2021 at 5:42 PM
    #207
    Appalachia Man
    Appalachia Man Well-Known Member
    03 Prerunner X-cab
    2.7L Detroit Truetrac 2" lift OME 880's & Dakar's
    i was on I24 between manchester and mounteagle tn. when mine went out, of course it was pitch black. had a spare bulb and change it out... got 1 working. next day pulled'em and both had melted in a blob of plastic. ordered ceramic terminals and led's off Amazon. watched a vid on "how to delete DRL's" cut the wire and was done with'em! been bout 3 mo ago, all good.
  8. Feb 4, 2021 at 10:38 AM
    #208
    Bolt Head
    Colorado
    crashnburn80, these are these the bulbs you're talking about, correct? BTW, the bulbs in the package are not the Philips but the OEMs I removed.20210204_101546.jpg
  9. Feb 4, 2021 at 11:24 AM
    #209
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. The +200s are evaluated in post #3169 here.
  10. Feb 4, 2021 at 12:26 PM
    #210
    Bolt Head
    Colorado
    Great, thanks. So far not super impressed with them in my first gen housings. They are whiter/brighter but don't seem to throw the light quite in the right place. I do need to verify proper aiming but I'm pretty sure if they're off it's not by much.
  11. Feb 4, 2021 at 12:28 PM
    #211
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You using OEM housing that haven't yellowed?
  12. Feb 4, 2021 at 12:31 PM
    #212
    Bolt Head
    Colorado
    Yes, new OEM from Toyota dealer only months ago
  13. Feb 4, 2021 at 12:37 PM
    #213
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Plug the bulb in but don't lock it down and hold it in place adjusting slightly by hand to see if the beam improves. Could need adjusting.
  14. Feb 4, 2021 at 12:41 PM
    #214
    Bolt Head
    Colorado
    I might try that but just thinking, If I find a better position how can I affix it there when there the 3 clocking tabs?
  15. Feb 4, 2021 at 12:44 PM
    #215
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can tape onto the blades to give it some space. I use HVAC aluminum tape.
  16. Feb 4, 2021 at 12:54 PM
    #216
    Bolt Head
    Colorado
    You know, now that I think about it I don't remember the bulb terminals being rotated slightly out of vertical and horizontal but these Philips are. I'm not 100% sure but that's how I remember it. Maybe I'll throw the OEMs back in there and see.
  17. Feb 4, 2021 at 3:06 PM
    #217
    tony2018
    tony2018 Well-Known Member
    Make sure they are clocked properly, never heard of this happening.
  18. Feb 4, 2021 at 3:52 PM
    #218
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Make sure the bulbs are seated properly, there is no rotating of adjusting on an H4, the 3 tabs will fix the orientation and there will not be a 'better one'. Adding the harness will help boost output some, you may see ~10% more, but adding the Osram Superbrights and the harness will provide significantly more output.
  19. Feb 4, 2021 at 4:18 PM
    #219
    Bolt Head
    Colorado
    I'll verify but I'm quite sure they are seated correctly. What I meant my rotated was that when installed, the bulb terminals are not exactly verical and horizontal by a few degrees or so and I don't remember seeing that before with previous bulbs.
  20. Feb 4, 2021 at 4:22 PM
    #220
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Ah. I'd be surprised if Philips had a manufacturing defect, but things do happen. The low beam glare shield below the low beam filament should sit perfectly level when installed.
