Proper headlight upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 29, 2015.
  1. Dec 30, 2015 at 5:16 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I wonder if you have many drivers flashing their high beams at you when your headlights are already on low beam.
  2. Dec 30, 2015 at 6:49 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Not yet. I think my headlights were aimed pretty low to begin with.
  3. Dec 30, 2015 at 9:04 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    THANKS to crashnburn80 for posting the original thread, and goldentaco03 for referencing it here in the 1st Gen forum!
    When I spoke with Ray at Susquehanna Motorsports today, he reiterated crashnburn80's recommended Ground Test Procedure. Based on crashnburn80's and goldentaco03's results with their '03s, I expected to find Ground Switching in my '04. Interestingly, the results indicate Conventional Switching. I suspect DRLs MAY be what drives the difference. (My '04 and crashnburn80's '15 both have them. He confirmed none of his older trucks, including the '03, had them. Waiting to hear from goldentaco03.)
    Can anyone confirm/deny my theory (i.e., NO DRLs = Ground Switching while DRLs = Conventional Switching)?
  4. Dec 31, 2015 at 12:20 AM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    My 96 doesn't have the composite headlights, of course. I went with GE Nighthawks and built my own relay harness. Made a huge difference in light output.
  5. Dec 31, 2015 at 12:38 AM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Crashnburn80's ultimate headlight upgrade is one of the the best modifications I've made to my truck!
    Props to Ryland, this dude is a class act.
    crashnburn80 likes this.
  6. Dec 31, 2015 at 4:18 AM
    goldentaco03
    Liam
    NJ
    That sounds correct. My DRL's are in my "turn signal" lens. Is the 04 different?
  7. Dec 31, 2015 at 5:30 AM
    low boy
    low boy 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    just pulled the trigger on some 70's... wicked sweet. thanks for the thread.
  8. Dec 31, 2015 at 6:12 AM
    amkaos
    amkaos Well-Known Member
    i wish i knew bout the 85w solution before i already did 70's ..
  9. Dec 31, 2015 at 6:45 AM
    Norton
    Thanks! Like you, I was almost positive my '04 would mirror your (and Crashnburn80's) '03. I'm betting all non-DRL First Gens probably do. Based on your description, it sounds like your truck does NOT have DRLs. (True DRLs are headlights that are always on, at a lower-than-low beam brightness, and not controlled by a manual switch.)
  10. Jan 1, 2016 at 7:20 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    So my 01 with DRL will take a different harness? Which #. Or I can go to crash&burns thread I guess.
  11. Jan 1, 2016 at 7:22 AM
    goldentaco03
    Liam
    NJ
    Go to crashnburn s thread and you'll see a link to the conventionally switched harness and the ground switched harness. But I would do the test that he talks about in the thread to make sure which harness to get.
    robertjohnsonjr and Norton like this.
  12. Jan 1, 2016 at 7:27 AM
    johnny3
    01 Tacoma TRD
    Thank you Liam.
  13. Jan 1, 2016 at 8:07 AM
    Norton
    +1 to ALL of this. HIGHLY RECOMMEND testing wiring before ordering.
    Truckstop13 likes this.
  14. Jan 9, 2016 at 12:49 PM
    Norton
    Bridge4 and goldentaco03[OP] like this.
  15. Jan 10, 2016 at 4:53 PM
    #35
    goldentaco03
    Liam
    NJ
  16. Jan 10, 2016 at 5:14 PM
    #36
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    I did the HID 6,000K 35 watts and Ballast, plug and play took 30 minutes for both sides total time and taping and wire tie, Heads and fogs Both !!! easy and both 6K 35 watts!
  17. Jan 10, 2016 at 5:39 PM
    #37
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    hopefully those are in projector housings/retrofits. and welcome to the 1st Gen section :D
  18. Jan 10, 2016 at 6:16 PM
    #38
    Rambo MARINE Recon
    Robert Goudin
    Regular OEM Housings ,cant afford projectors,had Toyota re aim and alighn !
  19. Jan 14, 2016 at 10:38 PM
    #39
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks for spreading the info to the first gen section.
    No, this is just flat out wrong. You cannot put an HID bulb in a halogen reflector lens and not blind oncoming drivers. You cannot aim them to fix the issue because the optics are not compatible causing significant scatter, meaning light escaping outside of the aimed region. Aiming them at the ground does not prevent light escaping outside of the aimed region and makes your distance driving worse (counter productive).
    You miss the point of this upgrade. It is a properly engineered upgrade for the technology used by the trucks factory lighting system. Meaning it it maintains the factory light horizon cut off, does not blind other drivers, is reliable, and has no negative effect other than shorter bulb life while having significant advantages such as a massive flood of light. If you want HIDs you need to do a full projector retrofit to do it properly.
    See this post for more explanation of scatter:
    https://www.tacomaworld.com/threads...de-not-led-or-hid.398066/page-5#post-11096831
    Low beam photos taken during a black out:
    https://www.tacomaworld.com/threads...de-not-led-or-hid.398066/page-7#post-11182996
    There is actually another step you can do to make this mod even better in light output than the composite light trucks, if your truck has sealed beams. Swap the sealed beams or whatever conversion you have in there for the Hella H4 E-code conversion housings. E-code lights are the European standard, they are far more focused than the DOT standard, they focus significantly more light onto the road and much less overhead wasted into the air. The housing alone makes a huge improvement, but the E-code conversion, plus the 85w bulbs, plus the harness practically gives your truck the power of the sun. It seriously puts to shame the results you see with the composite housings. I did this on my 2 Toyota pickups. I strongly recommend the Hella brand, as other brands I've tried did not fit snuggly and allowed the headlight to vibrate.
  20. Jan 15, 2016 at 3:44 AM
    #40
    pofarm
    Greg
    SW MO
    1996 Taco
    Yeah, I've looked into the E codes. I don't have the extra cash for them right now. I have to swap frames, so I need to save up for new shocks, struts, clutch, etc. Might as well replace the stuff while I have it all stripped down and easy access.
