Proper headlight upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 29, 2015.
  1. Jun 10, 2017 at 1:02 PM
    #101
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    They are flashing you for blinding them, not the brightness. I bet your low beam are all over the place (unless you are converted to projectors then correct me). LED bulbs don't work (cut off) in low beam reflector housing. This subject has been beaten to death on many forums.
    cruiserguy and crashnburn80 like this.
  2. Jun 10, 2017 at 1:03 PM
    #102
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What? People are not flashing you for brightness, they are flashing you because you have modified your headlights incorrectly. You need a full projector retrofit for most LEDs.
    Read this:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
    This halogen upgrade is brighter and outperforms LEDs as shown in that thread, and because it is done correctly you don't get flashed because it doesn't blind anyone.
    Tonemaz and cruiserguy like this.
  3. Jun 10, 2017 at 1:09 PM
    #103
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I understand the need for directional lenses. I also dislike them. Most of the people with the problem are the people who cut me off... so meh. I like my lights...and lenses.
    Edit: I read through most of that post. If Halogens are omnidirectional, that implies more scatter. I think the OP might have it a bit skewed. The LEDs I bought are tri-directional, not bi-directional like his. 3 COBs offset 120deg in a cocentric orientation, each with a radiation distribution of 120degrees, essentially creates a 360degree omnidirectional radiation pattern. So either my LEDs mimic halogens, or the OP of that post has it wrong.
  4. Jun 11, 2017 at 1:31 AM
    #104
    RysiuM
    Rysiu
    I think you missed the one important fact. For reflector type lenses it is extremely important where the source of light is located. For propper focusing the output light pattern the source (fillament) must be in exact spot. Even 1mm off will make light pattern undesired. This is why it is important to use quality bulbs - geometry of some noname H4 bulbs is so bad that they are useless.
    Any LED bulb us not able to replicate the position and pattern of H4 bulb. It is simple impossible. You bulbs may be oninidirectional but all LED chips are off center meaning each one is sending a "ghosts" out of the reflector. Just do the wall test an you will understand why are you flashed. Or simple stand in front of your car with eyes above the cut off line. You should be able to see only the light dispersed by front glass. If you see any light on the reflector it is bad.
    Or even simpler park your car on the stret at night with low beams on. Walk 50 yards in front of your truck and level your eyes about 3-4 ft above the ground. Look at your headlights. You will understand why you are flashed.
    One note to "proper headlight upgrade". Make sure your headlight glass is clean all the time. Plastic needs to be polished and free of brown spots. At high power bulbs the reflection of the glass makes the headlights glass blinding. Once driving in sheety weather I was flashed. I stopped, looked at my headlights and I understood why. Mud and dust on the glass made my lights glowing bright in all direction. Cleaning glass improved my visibility and cut off at the same time.
  5. Jun 11, 2017 at 9:29 AM
    #105
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Wow. So selfish.
    Your reply was to the OP of that thread.
    crashnburn80 likes this.
  6. Jun 11, 2017 at 10:33 AM
    #106
    treyus30
    Trey
    Mesa / AJ, AZ
    I'll take another look.
    I know yall are right and trying to get me to do the right thing...Unfortunately I just bought new headlight assemblies less than a month ago, after I ruled out that doing a projector conversion was out of my comfort zone. I wish this info would have revealed itself to me sooner. I could have sworn the my old halogens were the same aside from brightness and color temperature.
    Thanks for the oh-so-helpful contribution.
  7. Jun 14, 2017 at 10:23 PM
    #107
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I can certainly assure you I do not have my post wrong, and I can also assure you that your tri-directional LEDs do not mimic halogens and are not made by a reputable or credible manufacture, and you were sold cheap Chinese garbage. I did send you to my own thread to save time rehashing the same discussion I've had repetitively trying to educate others on lighting optics.
    Omi-directional halogen in no-way implies more glare or scatter, as clearly shown in the thread if you actually read through it. Using the same light source as stock produces the same light pattern as stock. Changing the light source changes the light pattern. Pretty simple, I'm not sure why so many struggle to understand this, it does not take an advanced engineering degree.
    Tri-directional LEDs are far worse off than bi-directional LEDs. Note how every leading LED manufacture uses a bi-directional design, including highly respected Philips which is the only mainstream LED manufacture that reputably claims to accurately reproduce halogen beam patterns in a reflective housing. There is no way you can accurately provide glare cut-off shields in a tri-directional design like you can in a bi-directional design. Not having precisely engineered glare shields in the same formation as the halogen design means you will omit excessive glare. Knowing this and continuing to run them anyway is an asshole move, I'm not going to give any sympathy. Just because you did not do your homework ahead of time is no reason not to correct and do it the right way now that you know better.
    Digiratus likes this.
  8. Jun 15, 2017 at 4:56 AM
    #108
    RysiuM
    Rysiu
    In California there is no "safety inspection" on cars, so people decorating they cars or trucks like a Christmas trees. If I flash everyone I see I would have to replace my burned high beam bulbs every month. I just settled for acknowledging the fact that ignorance and advanced technology don't mix. Many drivers think that lights on a car have decoration purpose only ("looks cool, dude").
    Now in Poland it is different story. Each car has to pass safety inspection every year and that's including not only correct lighting pattern but also correct aiming (there are actually devices to measure that). On the top of that HIDs are allowed only if there is automatic headlight leveling system and wipers (with sprinklers) installed on headlights. The last one is for the reason I wrote before. It is nice for the change to actually see the road in your own headlights without not squinting when the oncoming traffic arrives.
    Sorry, for venting out.
  9. Jun 15, 2017 at 1:17 PM
    #109
    Austintaco
    Austintaco Well-Known Member
    Patrick
    Austin,TX
    03 DC TRD with some stuff
    King coilovers, Tundra brakes, All pro Expo springs, Timbrens, ARB bumper, All Pro Sliders and Rear bumper, Landcruiser wheels, sold my Flippac, regeared to 4.88’s, ARB front Locker
    It turns out that my 03 with DRL's in the headlight is ground switched. I did the test multiple times and I always had some voltage on the common terminal. EDIT: It is conventionally switched and if you have DTRL, you will need to use the conventional harness and disable DTRL by snipping the white wire with green stripe on the DRL relay/box behind the lower panel between the steering wheel and the radio.
  10. Jun 15, 2017 at 1:33 PM
    #110
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    CA's "safety inspection" is when you get lit up by a CHP for blinding them on the highway and you get a fix it ticket. Happens all the time, well, at least it used to. Years ago, my brother was driving down the road, following a chippy, guy pulls over, lets my brother pass, then lights him up.
    Having proper lights is *especially* important in trucks, and even more so when they're lifted 4x4's. Our lights start out so much higher than a car's, that even small amounts of scatter is really annoying to other motorists. People think that they're getting flashed just because they're in a truck, but that's not true, it because 1) you suck at aiming your lights, or 2) you did a poor job upgrading your lights.
    The funny thing is that even though I drive a 4x4 truck, I still get blinded by stupid Civics with their "bro" headlights. I enjoy showing them my brights, although they are probably too dumb to realize why...
    BluefinTaco likes this.
  11. Jun 15, 2017 at 2:20 PM
    #111
    RysiuM
    Rysiu
    Thy think you are warning them about a speed trap. Quite common for old cars with plastic faded headlights. Guy thinks putting a HID or LED is a solution to his crappy headlights. They are hopeless.
    If CHP would pull over every car with improper headlights there will be no officers to respond to accidents (at least in Sacramento area). On my daily commute I could count at least ten cars like that every evening.
  12. Jun 16, 2017 at 8:37 AM
    #112
    jbrandt
    Justin
    Nah, one of the roads I drive (that I find myself having an issue with glare) is a two lane residential road with stop signs almost every block. No speed traps there...
    Headlights aren't exactly an enforcement priority, that's true... That said, it can, and does happen. Hell, one of the more "popular" reasons to get lit up is a broken taillight (though more often than not, that's just a reason to pull over a "suspicious" vehicle)... I even got pulled over in OR because one of my license plate lights was out (he told me they were both out, but I realized later I still had a good one, so I was basically pulled over for CA plates...)
    I did the "proper" headlight upgrade, minus the 80w bulbs. Though for the 1st gens, you don't have a lot of options for reflectors, so I just went with new CAPA certified housings, and the HD wiring harness. Just the now (non faded and cloudy) housing by themselves obviously made a big improvement, and I'm waiting on the 80w Osrams until either my current ones burn out or I find I wand more light. So far, though, I'm pretty happy.
  13. Jun 16, 2017 at 9:26 AM
    #113
    RysiuM
    Rysiu
    For the proper upgrade the first thing I did was dumping factory H6054 for Autopal 200mm with H4 bulb (I also have Hela as a backup). The second was dumping junk H4 bulbs that came with the lamp and I put Sylvania SilverStar H4 bulbs. No glare and 100% of 55W is on the road. After that I never had any need for HID or LED.
    High beam are also more focused with Autopal (compared to H6054). Strange pattern with two darker areas just in front of the truck which I think is good, because road close to the truck does not blind and over-shine the distant objects. I have never tried Hela, but I read only good thing about these lamps.
    And lastly, I saved my SilverStar bulbs from being used as a DRL (required by the law in Poland) by installing real LED DRL certified by Osram in the inserts under the headlights. All legal, safe and proper :yes:.
  14. Jun 16, 2017 at 9:39 AM
    #114
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You have E-codes lamps I'm guessing since you are in Poland, way better than the N.A. DOT headlight assemblies here. I always swap my headlight assemblies to E-code if possible.
    Are you running sylvania silverstars or osram silverstars? Same parent manufacture but very different bulbs. I ask because in the EU I thought Osrams were more common. Sylvania silverstars are actually not a high performing bulb (just fully coated and whiter making it look brighter), you will get better results at stock wattage with the osram silverstars (not coated) or osram night breakers. Both are spec'd to put out noticeably more lumens that the sylvanias.
  15. Jun 16, 2017 at 10:30 AM
    #115
    RysiuM
    Rysiu
    Guess what, it is next to impossible to buy 200mm lamps in Poland. I bought E-code Autopals on ebay almost 2 years ago and I used them in USA for almost year and half. This is why I brought German made Hela from USA, as somehow this size is not available here.:crazy:
    For sure they are Sylvania as I did not change bulbs here yet. They are from Walmart USA :). Now I might messed up with "silverstar thing" as they are one dot lower price, without the blue coating (I knew better than that :D). I need to find out what was the name of that model. There were like three types of Sylvania available: Long life, short life bright, and the blue thing. Mine was short life bright, but still I have them for more than a year.
    When the time comes to replace them in Poland, I will get Osram without blue tint for sure.
  16. Jun 17, 2017 at 8:58 PM
    #116
    Kalibr
    Kalibr Member
    Just did the upgrade on a 2003 Tacoma with this harness from Mike Cline http://www.headlightservices.com/Wiring.html
    Looks like a high quality product and the install went without any issues. It is also not as expensive as the rally lights harness, which looks like it went up in price since it was originally mentioned in this and the related thread.
  17. Jun 18, 2017 at 2:02 AM
    #117
    1HItaco
    1HItaco Well-Known Member
    trying to find out if my 2004 has conventionally switched or ground switched and after testing i get conventionally switched.
    when i hook up my multimeter and turn on truck with headlights OFF i get 14 Volts from "left" terminal of headlight plug to negative terminal on battery.
    when i turn on the headlight 14V goes away and only mV is read (under 1V).
    I assume this means I have the conventional type switching headlights like the 2015 models.
    can anyone help confirm this
  18. Jun 18, 2017 at 8:11 AM
    #118
    RysiuM
    Rysiu
    What the heck is "conventionally switched" or "ground switched"? If your truck (2004) is without DRL (used in Canada) it has the following headlight diagram:
    Which is simply saying the same as all 1st gen Tacomas. In earlier models ECU did not control Head Relay for auto switch off lights feature. The rest is the same as everyone of us. The whole current from the bulb runs through headlight switch to the ground. Now if you have Canadian version with DRL the diagram is a way more complicated and whole bunch of relays is involved in switching the current (including DRL relay integrated circuit).
    It is actually funny the way Toyota did Hi-beam indication on the dash. You can see that the indicator bulb is connected between ground and low beam filament. When lights are working at Low-beam, the low beam filament is grounded via the light switch so the Hi-beam indicator bulb is not illuminated. At High-beam, the low beam filament is not grounded so the current runs through low beam filament and Hi-beam indicator bulb. So all will work as long the low beam filament is not open (or high resistance) in both (left and right) bulbs. HID or LED drivers may not allow for current to flow via low beam connector when Hi-beam is turned on and this is why people are complaining about Hi-beam indicator light not working with some HID or LED bulbs (which is OK, because unless you have projector retrofit, you shouldn't be using HID or LED in 1st gen Tacoma headlights anyway).
  19. Jun 18, 2017 at 8:45 AM
    #119
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The left terminal you are referring to is the left one when plugged into the bulb and viewed from the driver seat, correct? Not to be confused with left when facing the truck.
    Aka is it the same as the picture I have in the Ultimate headlight upgrade thread showing the test configuration? I don't believe mine ever had any voltage in a 2015, does your truck have DRLs?
  20. Jun 18, 2017 at 8:55 AM
    #120
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Others have purchased from there too, they look like equally as high quality kits.
    Ground switched vs conventionally switched is the method Toyota uses to complete the circuit on the dual filament headlight, completing the ground to activate the circuit or completing the positive connection to activate the circuit. The different methods require different relay configurations on the standalone harness.
