Proper procedure to turn off AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by horstuff, Jul 15, 2015.
  1. Jul 15, 2015 at 9:54 AM
    horstuff
    horstuff [OP] Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    I have *heard* that you should NEVER turn the dial from cold to hot with the AC button on, it will fry your AC system in a hurry. True?
    If so, what is the best way to do that? Seems like a moron question, and maybe it's because the truck is brand new to me, but I haven't yet been able to come up with a good order in which to go from AC to heat. Up here in Seattle, it's been hot during the days, cool in the mornings, so I have been going back and forth between heat and AC. Just wondering if it even matters how you do that. If not, I'll stop worrying about it, tell my "source" that they're full of it, and continue head on down the highway.
  2. Jul 15, 2015 at 9:56 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Fry what? Your source sucks and I would never buy he or her a beer again.
    The best way to turn it off... drum roll.... just turn it off. Best way to change from AC to heat is... just turn the dial from heat to ac.
    Mast3rSkywalk3r likes this.
  3. Jul 15, 2015 at 9:59 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    In the past on previous trucks I have had both heat setting on and ac button pressed on. No damage.
  4. Jul 15, 2015 at 10:00 AM
    horstuff
    PNW
    *They* (who shall remain beerless, at least from me) said that if the AC button / light is on, and then you turn the dial from cold to hot, there goes your AC unit. So, I have been vigilant about turning the knob to cold, then turn the fan on, then see if the AC light is on, and if it is, turn it off, and then turn the know from cold to heat. Again, if none of this matters a hoot as far as protecting the AC unit's longevity, then I'll just do the drumroll obvious things in the order that I see fit.
  5. Jul 15, 2015 at 10:04 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    AC Evaporator is in front of Heater core. So cool air will get heat up when you have A/C on when things are set to full heat.
    This also works great if you need run in Dehum mode with out making your truck freezing (in colder but humid env. during maybe rain)
    You can not do damage it even if you tried...
  6. Jul 15, 2015 at 10:08 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    You can absolutely use the AC while using the heating core(hot on the dial). The AC will help dry humid air but sometimes it's too cold to keep the temp dial on full cold. You can blend it anywhere you like.
  7. Jul 15, 2015 at 10:40 AM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Whoever told you that is very wrong. Cars for the last decade or longer have had the AC on automatically when defrost is turned on as it dries the air out.
  8. Jul 15, 2015 at 10:43 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    exactly, think about it Toyota would be spending millions to fix under warranty. This sound like internet mumbo jumbo
  9. Jul 15, 2015 at 10:51 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The air conditioner is running in defrost mode (hot air).. so..
  10. Jul 15, 2015 at 10:51 AM
    KCEllwood
    KCEllwood Well-Known Member
    Rural Maine
    2022 Lunar Rock TRD Sport DCSB 6 Sp Auto
    I do use the heat quite often and have for many years across many vehicle. As stated above, it is a great way to dehumidified the air on cool mornings and take care of inside window fogging. Many articles written about this very subject on the internet.
  11. Jul 15, 2015 at 10:51 AM
    T4RFTMFW
    Fuck!
  12. Jul 15, 2015 at 10:52 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    This thread is full of wut.
  13. Jul 15, 2015 at 11:11 AM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    You've been lied to. AC and heat on at the same time is the quickest way to defrost/defog your windshield.
  14. Jul 15, 2015 at 11:18 AM
    horstuff
    PNW
    ok, done deal. My source has been demoted to 3 notches below hoi polloi.
  15. Jul 15, 2015 at 4:58 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :rofl::rofl:....... This thread
  16. Jul 15, 2015 at 6:53 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Do it anyway you want you will be fine.
  17. Jul 15, 2015 at 6:55 PM
    scocar
    scocar hypotenoper
    If this were true, the auto industry would implode.
  18. Jul 15, 2015 at 7:10 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The AC is also a dehumidifier. I use AC along with heat all the time during winter to keep the windows from fogging. On most older vehicles the AC came on automatically when you set it on defrost, hot or cold. In an effort to improve fuel mileage you now have to manually turn on the AC along with defrost in order to keep the windows clear.
  19. Jul 15, 2015 at 7:16 PM
    Larry
    Larry CARL
    CARL
    A/C stays on pretty much all the time.
  20. Jul 15, 2015 at 7:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The funny things some people say... heat mode will burn out the AC :)
    But, If you cough, sneeze, burp and fart at the same time your head will blow up. Now that is a fact!
