Proper rear shock size
Discussion in '5 Lug' started by bobbyhill, Mar 13, 2018.
  1. Mar 17, 2018 at 7:49 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Ride was the same. And its pretty easy to install. And if you havea problem with your tires rubbing under full compression this is how you fix it. In the rear it does the same thing. Stop the tires from going into the wheel wel especially if your over loaded in the rear. Also stops the leafs from bowing the wrong way
