Proper spring rate for a 3rd gen for max flex
Discussion in 'Suspension' started by FloridaFree, Apr 29, 2022.
  1. Apr 29, 2022 at 1:20 PM
    FloridaFree
    FloridaFree [OP] Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    This is a repost.. didn't get answers...
    I'm insecure about losing droop with my 886 coils. I know the shocks add ~1.5 inches of travel or so, but the way my truck is lifted I am using all that travel at ride height. I'd like to reduce the lift for more travel. Id like to reduce the spring rate for better flex purposes.
    Is this worth spending the time and money to do? Or would adding sliders and skids make it better?
    I think the armor won't fix the issue. I suspect it would reduce ride height, but flex would be hindered by spring rate
    Thank you in advance
  2. Apr 29, 2022 at 1:28 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    This is not on 5100 shocks. This is on nitrochargers
  3. Apr 29, 2022 at 2:07 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Stock is 717 pounds, you are at 660 for the 886 i personally wouldn't go any lower in poundage or you will see some sag.
    More droop? Get rid of the sway bar, get aftermarket UPC because that is probably the next limiting factor, then the limiting factor is likely your CV axles which you might not be able to change much with it.
    Key-Rei likes this.
  4. Apr 29, 2022 at 2:14 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    I don't have sway bar and I am lifted 3 inches. I am getting more droop by reducing lift I mean.
    The stock spring is 14 something inches. The ome 886 is 15.8, so the preload is higher for OME.
    I want to know if I will see an increase in flex with a lower spring rate. Also if the 888 will give 2.5 inches over sr5 height or offroad height
  5. Apr 29, 2022 at 2:50 PM
    TacoTuesdayNJ
    TacoTuesdayNJ Well-Known Member
    Spring rate is one of many factors in flex. U need to have correct spring weight for the weight of your truck including accessories. Then the correct travel shock from max up travel to droop. Limiting factors are: ball joint bind, axle cv bind, sway bar, shock length. Spring rate controls your weight. Shocks control suspension compression and rebound.
    Also lift has nothing to do with your travel. Most bolt on lifts actually have less travel then your stock suspension. Being that it is decreasing down travel for the lift it's giving you.
    Key-Rei and JFriday1 like this.
  6. Apr 29, 2022 at 3:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  7. Apr 29, 2022 at 3:15 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
  8. Apr 29, 2022 at 3:19 PM
    gudujarlson
    Minnesota
    Ok, you should understand then that coil springs and ride height have no effect on suspension travel. Or maybe you are just using different definitions of terms than I am used to.
  9. Apr 29, 2022 at 3:22 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    what do you mean?
    A lift will have an effect on suspension travel. The total travel of course remains the same, but your down travel decreases and up travel increases
  10. Apr 29, 2022 at 3:26 PM
    gudujarlson
    Minnesota
    My definition of suspension travel is the distance between the lowest point to the highest point that the hub or axle can reach. This is pretty common in motorized vehicle communities.
  11. Apr 29, 2022 at 3:27 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    ok whats your definition of down travel?
  12. Apr 29, 2022 at 3:39 PM
    gudujarlson
    Minnesota
    The distance from ride height to the bottom of the suspension travel.
  13. Apr 29, 2022 at 3:50 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    I want to reduce my lift because it has reduced my down travel.
    I want to regain more usage of the travel with a lower spring rate.
    Next I plan to add 300 lb of armor at some point.
    I am considering OME 888 and OME 887, but I can't find whether the amount of lift they provide with nitrochargers is over sr5 height or lift over trd OR height.
  14. Apr 29, 2022 at 4:00 PM
    gudujarlson
    Minnesota
    By a majority of reports I have read, the ride height of all trims is identical with the exception of the Pro.
    ARB gives an approximate optimal weight rating for their coil springs and also an approximate 2” increase in ride height at those weights. If you really want to dial in the ride height, I suggest a coilover with adjustable preload.
    I’ve adjusted the preload on my kings twice. It makes a minor difference, but I’m having fun tinkering with it.
  15. Apr 29, 2022 at 4:13 PM
    gudujarlson
    Minnesota
    One other thought… maintaining some down travel is a good thing. Many people don’t take this into account when modifying their truck.
  16. Apr 29, 2022 at 4:15 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    thats my goal. Most good aftermarket shocks have "extended travel". I have 9.5 inches of travel. I am trying to get down to low level of lift and fit some 35s when my stock tired go bald
  17. May 11, 2022 at 11:51 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I run 13" 600lb springs, with a full plate bumper, winch, heavy ass skids, etc. Sits at 1.5" over stock with the max amount of preload before coil bind.
  18. May 12, 2022 at 12:06 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Mid travel or long travel for max flex. Everything else is similar to stock numbers.
    Rear end is easier to gain some flex by going with longer shocks.
    TacoTuesdayNJ likes this.
  19. May 12, 2022 at 9:59 AM
    FloridaFree
    TRD OffRoad 4x4 mgm
    A lot of aftermarket shocks have more travel than stock. Look at bilstein 5100. The pro has more travel as well. I think it's called extended travel
    Yes long travel or SAS is down the line. Maybe in 5 years
  20. May 12, 2022 at 11:20 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    If I remember right, the 5100s actually have more travel than any other front bolt in/stock configuration out there. More than the Fox/King/etc "extended" travel.
