Proper Tire Pressure
Discussion in 'Wheels & Tires' started by bobzilla, Jun 16, 2016.
  1. Dec 2, 2016 at 7:24 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    my sidewall says 51 psi:eek:
  2. Dec 2, 2016 at 7:26 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Don't do that
    drizzoh, flx, OilCapital2021 and 3 others like this.
  3. Dec 2, 2016 at 7:31 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Sidewall number has nothing to do with the amount you are supposed to run. That is the Maximum inflation which corresponds to the pressure you run if you are running the tire at max load.
    swellcat, shakerhood and Garyji like this.
  4. Dec 2, 2016 at 8:39 AM
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    ^^^ What he said!!
    I can see a pound or two, but the factory has that noted for a reason, so it's better to follow that. Granted, I'm not saying Ford was right w/ what they did in the 90s w/ Explorers, but the door jam (or manual) is what you should always use.
    For what it's worth, my tires came back after my 5k mile service the same as the OP's did. Just bled a bit off and good to go. At this point, I don't trust my dealership at all, but that's just me.
  5. Dec 2, 2016 at 10:22 AM
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
    Picked up my
    Truck from the dealer with 32 all around
  6. Dec 2, 2016 at 2:46 PM
    vondy
    vondy Well-Known Member
    Dallas, Texas
    2016 Tacoma TRD Off-Road 4x4 Magnetic Gray
    I definitely make my own psi adjustments. Was just curious if there was something I didn't know about with the off road since the dealer had different specs.
    I would hope everyone knows that max psi on the side of the tire is NOT what you are supposed to run them at.
  7. Dec 2, 2016 at 2:59 PM
    jameshartman69
    jameshartman69 Well-Known Member
    Jim
    2016 Tacoma TRD
    Dealer always screws up the pressure, my tires say 80 psi but I run them at 34. Dealer sets them at 38.
    Dodge or Toyota dealer does it so not just Toyota
  8. Jul 14, 2018 at 12:09 PM
    tacotruck93
    tacotruck93 Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    I know there are a lot of threads out there about tire pressure. I just don't have the time to though them all. I was wondering what tire pressure I should be ridding on my 285/75/16 toyo open country r/t. Thanks for the help .
  9. Jul 14, 2018 at 5:11 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'd start at about 40 psi and experiment. The chalk test is good. Draw lines across the tires with chalk and go for a short drive 1/4 mile is enough. If there is still chalk showing on the edges then you have too much air and only the center of the tire is in contact with the road. Let air out until you get even wear.
    Tacomania19 likes this.
  10. Jul 14, 2018 at 6:01 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  11. Jul 14, 2018 at 6:06 PM
    tacotruck93
    Zach
    Akron,Ohio
    Awesome thank you !
  12. Jul 14, 2018 at 6:21 PM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    40!??:eek: You will find that the best pressure is around 30-33 mark.
  13. Jul 14, 2018 at 8:22 PM
    TacomaDaveB
    TacomaDaveB Active Member
    Dave
    18 TRD Off Road
    36 all around on mine. Feels good for my daily ride and gas mileage is good but definitely soften them up for off road
  14. Jul 15, 2018 at 6:35 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    I should take some air out of mine it says max PSI 80. What should I run them for daily use
  15. Oct 2, 2018 at 10:06 AM
    #35
    McDudesYota
    McDudesYota Well-Known Member
    Sean
    Sacramento, Commiefornia
    2007 DCSB Sport with 3 pedals
    Just got it!! Last guy did a couple things.... some good, some bad.. Jump forward almost 2 weeks, I’ve put on a HS Off-road 2” lift kit with 5100s all around, new springs, and a AAL in the rear, with TRD 17x7” SEMA wheels wrapped in 255-80-17 Toyo Open Country ATs Installed InSight Retrofits HIDs, look friggin' sweeeet Husky Weatherbeater Action onboard
  16. Dec 5, 2018 at 11:18 PM
    #36
    VewDew
    VewDew W7ZOM
    Seabeck, WA
    19 Taco TRD Pro / 13 LC200
    flx and ardrummer292 like this.
  17. Apr 15, 2019 at 8:25 AM
    #37
    Mike13027
    Mike13027 Well-Known Member
    2019 Magnetic Gray Metallic TRD Sport LB
    Weathertech mats, FLEX tonneau, weathertech vent visors
    Mine came from the dealer with 34 psi cold. I had a screw in my left rear tire just over 700 miles. Had to replace the tire because it was on the very outside. Had the dealer put the tire on and when I got it back PSI was at 29. I’m so used to running 32 in every vehicle I had I thought they didn’t put enough in. Checked my door badge and it says 29 so I aired the rest down to 29 as well.
  18. Dec 26, 2019 at 10:19 AM
    #38
    faction95
    faction95 Active Member
    Glendora, CA
    2020 White TRD Pro
    Mine came brand new from the dealer with 32 psi cold. I aired them up to 35 with daily commuting in mind.
  19. Jan 14, 2020 at 6:25 AM
    #39
    Falcon5Romeo
    Falcon5Romeo Active Member
    Tex
    2019 Tacoma SR5 Magnetic Gray
    Mine came from the dealer at 29 all around, and I've kept it that way. They do look like they're slightly bulging at the sidewalls though, compared to other cars in the lot.
  20. Jan 14, 2020 at 6:12 PM
    #40
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    P/245/75/16/109?
    Should be 32 psi.
