proper u joint greasing method.
Discussion in 'General Automotive' started by ywen, Mar 6, 2011.
  1. Mar 6, 2011 at 12:14 AM
    ywen
    ywen [OP] Well-Known Member
    i've always pumped enough grease to get the old grease out.
    the guys at the shop I go to told me that I put too much grease into the u joints and I'd be breaking the seal at that point.
    Does this rule vary depending on the type of u joint? Or are there just way too many contradictory rules out there regarding this?
  2. Mar 6, 2011 at 12:17 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    I just pump it until you heard it purge
  3. Mar 6, 2011 at 5:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I pump until I see new grease coming out...
  4. Mar 6, 2011 at 6:06 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Everything I've read says to pump until only a little of the old grease starts to come out. I too have thought about forcing all of the old grease out, but I think at the end of the day the intent is to just ensure the bearings are not starved of grease.
  5. Mar 6, 2011 at 7:27 AM
    ywen
    what is the difference between allowing all the old grease to come out vs just some? I mean, by that point, you've already opened seal...
    This answer must be something very black n' white.
  6. Mar 6, 2011 at 8:09 AM
    larryde09
    Larry
    Boston, MA
    I think the difference is that you need to push in a lot of new grease to push all of the hold out. The point is not that the seal is broken, which is misleading because it is not really a "seal" because it is not a closed/sealed system...hence why you have to regrease it and know it has received new grease when some old comes out of the seals.
    Therefore, you don't need a lot of grease to refill the joint and force just a little out of the seal. However, you likely need much more grease and therefore increased pressure to push all of the old grease out. This increased pressure likely overfills or over stresses the bearigns, joint, and seals. For example, you may want to simply regrease the bearings, but too much pressure may irreversibly break/damage the seals or lodge the bearings with overloaded grease, etc. This is my impression, and everything I've read just says to force a little old grease out.
