Proper UCA with 2” lift?
Discussion in 'Suspension' started by Bleeds, May 10, 2023.
  1. May 10, 2023 at 6:04 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    I need to replace my UCA and currently have a 2” lift. I didn’t own the vehicle prior to the lift but it seems to me it’s an OEM UCA. The real question is I recently added new shocks and the springs have yet to settle and I’m concerned that it’s too much stress on the UCA ball. I’ve seen reference to OEM/non-lift UCA’s being fine with lifts of 2.5” or less. What’s everyone’s thoughts on my current situation? Is there any danger of replacing with standard UCA and wait for the springs continue to settle? The shocks are KYB SR4463/4464. If I should get UCA’s meant for a lift, what are recommended? It’s mainly an on-highway rig. TIA
  2. May 10, 2023 at 6:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
  3. May 11, 2023 at 7:03 AM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    But are there any that people recommend? Any brands to avoid?
  4. May 11, 2023 at 7:14 AM
    lilyota12
    lilyota12 Well-Known Member
    Shredona
    2012 Tacoma DCSB 4.0 TRD Off-Road
    See Build Thread
    Pretty much any aftermarket non-oem style will fit the bill if you want to replace the OEM ones. For the most adjustability you can't beat SPC arms. I have Camburgs and SPC, both are great. If you need over 4 degrees + caster then you'll almost certainly have to get the SPCs though.
  5. May 11, 2023 at 8:26 AM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Ok thanks. I’ll look into them
    lilyota12 likes this.
  6. May 13, 2023 at 11:35 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    arbezee and Tiedie like this.
  7. May 13, 2023 at 1:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Imo. Either SPC or JBA.
    Tiedie likes this.
