Proper warm up before engaging transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Neo177, Nov 13, 2019.
  1. Nov 14, 2019 at 7:56 AM
    #41
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Ain't that the truth. On days like that mine sometimes draws all the way up to my knees. o_O
    oconnor and The hammer[QUOTED] like this.
  2. Nov 14, 2019 at 8:03 AM
    #42
    birdbrooks
    birdbrooks Well-Known Member
    Bill
    2025 Tacoma TRD Sport in Supersonic Red
    All-factory options at this point.
    I guess you're supposed to be able to fire up your rig and drive right off in cold weather. But tell that to folks in MN or likewise ass-cold-winter states. A lot of us go out there and fire it up, go back inside the house and let it warm up for several minutes before we leave. Otherwise, you're getting into a cab with stiff steering, sluggish shifting, iced up windows (try scraping glass without pre-warming on a -20 day if you want to really have fun) and bone-ass hard freezing seats. If you want to avoid parking brake freeze-ups in winter here, unless you're forced to park on a slope, we don't use 'em.
    So, I might be breaking rules by not driving right off, but, yea, guilty as charged.
    lojack, oconnor and The hammer like this.
  3. Nov 14, 2019 at 8:12 AM
    #43
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Here's the thing with the long engine warm-ups. You're wasting a lot of fuel and warming up a LOT slower because there is no load on the engine, it’s just spinning not working. If you move the load creates friction and heat.
    But I get it, unless you have a garage, the front and rear W/S maybe frozen and so are the side mirrors. But TG for the electric heat on our truck, I get heat in about 2 minutes
    Cheers!
  4. Nov 14, 2019 at 8:45 AM
    #44
    birdbrooks
    Bill
    I hear you, Hammer, and agree. I keep the warm-up to just a few minutes but it does help (at least my mind). Now with my new '19 Tacoma, I've got seat heaters, and outside mirror heaters too, so that makes it all a bit less of a pain!
  5. Nov 14, 2019 at 9:19 AM
    #45
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Yes the torque converter generates alot of heat especially if you're running a high stall converter . The converter in my Camaro is a 9" converter that has a stall rating of 4500rpm and it's a very loose converter
  6. Nov 14, 2019 at 9:26 AM
    #46
    HoneyBrownFan
    HoneyBrownFan Well-Known Member
    Georgia
    2021 T4R TRDOR
    Don't go to that dealer again. The epitome of telling a customer BS to get them out the door.
    The hammer and GreyBaldTaco like this.
  7. Nov 14, 2019 at 9:48 AM
    #47
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    It will not warm up the transmission at all if it's in Park. Put in neutral and the pump(s) circulate trans fluid, which warms the fluid very quickly. Should be SOP for anyone starting an aut trans in very cold climates.
  8. Nov 14, 2019 at 9:48 AM
    #48
    RikMart
    RikMart Well-Known Member
    Rhode Island
    2017 Tacoma TRD Off-Road
    -TRD Pro Grille -Husky Xact contour mats -2nd Gen Runner-board -LED interior Lights -Denim Cotton Seat covers -CaliRaised 30in LED Bar -KC Led Fogs -XenonDepot 5000k HID
    I've had this issue before and it wasn't the transmission. The issue where the rear drum brakes/E-brake freezing due to moisture. The transmission has never given me issues during winter(in New England). Yes, it is good to warm up the engine/transmission but not necessary. You can drive it cold, just make sure you don't over-rev the engine and drive slow-ish until it engine reaches normal operational temps.
    The hammer likes this.
  9. Nov 14, 2019 at 3:52 PM
    #49
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    I have had block heaters in the past and your engine and water temp stays about 140. Get in and drive when its 20 out.
  10. Nov 14, 2019 at 3:54 PM
    #50
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It will indirectly through heat transfer, just not as efficiently.
  11. Nov 14, 2019 at 8:26 PM
    #51
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    The transmission pump spins off the crank, not the driveshaft. So, no, being in Park circulates just as much fluid as being in neutral. If anything it would warm up quicker in park as the torque converter’s rear fins would be held stationary, causing more fluid friction as the engine rotates the forward fins past them
    moreover it shouldn’t /need/ to warm up. If it’s not going into gear immediately after start-up you have a fluid level or pump/pressure issue
    Skydvrr likes this.
  12. Nov 15, 2019 at 6:40 AM
    #52
    birdbrooks
    Bill
    Cheers![/QUOTE]
    Hammer, I forgot to ask, are you referring to "electric heat" as in an engine block heater, or some Toyota feature I'm not aware of? Thanks! Bill
  13. Nov 15, 2019 at 7:19 AM
    #53
    gearcruncher
    Canadain bumper technician
    These transmissions ( AC60 series ) circulate the fluid in Park as well as Neutral . Are you a former Dodge owner ? Where did you get this information from ? If you look through the schematic , the 3rd gen transmission has a pre-heater . Start your truck and allow the engine antifreeze to warm your transmission . With this being said and only if the OP didnt use his parking break , there is a possibilty the transmission could be low on fluid . Now that the weather is cooler , it takes more time for the transmission pump to supply cold fluid to the forward clutch pack . https://www.tacomaworld.com/threads...be-low-on-fluid-directly-from-factory.405642/
  14. Nov 15, 2019 at 7:41 AM
    #54
    AKGSD
    Joe
    Alaska
    Hammer, I forgot to ask, are you referring to "electric heat" as in an engine block heater, or some Toyota feature I'm not aware of? Thanks! Bill[/QUOTE]
    There’s an electric heater core to supplement the coolant heater core, since these motors are so cold-blooded
  15. Nov 15, 2019 at 9:32 AM
    #55
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    You're thinking of old Chrysler TorqueFlite transmissions. Those didn't pump fluid in PARK and even the dipstick specified to check the level with the gear selector in NEUTRAL only. Just about every other transmission manufacturer pumps fluid in the PARK position.
  16. Nov 15, 2019 at 11:41 AM
    #56
    desmodue
    2016 TRD OR AC
    I was given this information years ago, and it proved to be true, at least for the vehicles at the time. Yes, it was specifically Chrysler products...1994 3.9 V6 Dakota, 2002 5.9 V8 Dakota. It really helped to warm the trans up when leaving work in the middle of February with wind chills below zero. If I started the truck and let it warm up in park, the windows were defrosted and the heater was blowing tons of warm air, but the trans was sluggish to shift for the first few miles. Warm it up in neutral and it performed normally.
    So, I have done this with every vehicle I have owned since then. Apparently it wasn't necessary, but old habits die hard. But I can learn, thanks.
    TorqueFlites were a long time ago, 1960's and 70's. Chrysler autos at least up through the 45RFE (until early 2000's) still didn't pump in park. I don't know about after that time, maybe they changed after that...but my last Dodge was my last Dodge
  17. Nov 15, 2019 at 2:41 PM
    #57
    gearcruncher
    Ahh yes the dreaded Torque flite . You can now purchase a new manual valve that allows the torqueflite to warm the engine in Park . The new manual valve also has many advantages over the original manual valve . I install one of the upgraded manual valves in every Chrysler transmission I overhaul .https://www.sonnax.com/parts/1835-manual-valve
    TacomaSport86 likes this.
  18. Nov 15, 2019 at 4:40 PM
    #58
    The hammer
    There’s an electric heater core to supplement the coolant heater core, since these motors are so cold-blooded[/QUOTE]
    ^^ Yep, what he said^^
  19. Nov 15, 2019 at 4:48 PM
    #59
    The hammer
    "I've had this issue before and it wasn't the transmission" - Correcto mundo!
    But it appears some here would like it to be and always blame the transmission saying it's low on ATF fluid from the factory.
    EVERY TIME! :rofl::rofl:
    In this case, I'm more inclined towards the parking brake, simple solution, leave it off and see.
    If it should still act up, it's still not the transmission low on ATF fluid, its a software issue and there may be a tsb at the dealer.
  20. Nov 15, 2019 at 5:32 PM
    #60
    Mcsosgt110
    Mcsosgt110 Well-Known Member
    Northern California
    2016 Trd offroad
    In the works
    Well there has been a lot of good and some not so good responses, I also have a 16 offroad. My winters can be minus 20 to low teens and so on. My tranny has never been an issue. But as some people said if the truck is parked with moisture in the drums, they will freeze . I try to be careful as you
    take off but that's horse crap about the warm up stated by the dealer. Just placating you until next time. Common sense when cold is to warm up at least 30 seconds or little more. If it was my truck I would make sure the trans fluid was full. Good luck.
    birdbrooks likes this.
