proper way to level Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by montanabay, May 23, 2010.
  1. May 23, 2010 at 12:35 PM
    montanabay
    montanabay [OP] Active Member
    CA
    2.7L 4WD AUTO
    Hi All,
    I have a 1996 2.7L 4WD Tacoma, I put spring helpers in the back to reduce sag when I have load. The result is the rear is about 1" higher than the front. The front struts do need replacing, which I plan to do, but my impression is this won't give me a 1" in the front right? So, what is the best way to raise up the front just an 1". I've accomplished this with torsion bars, but the 4wd model is spring/strut front suspension.
    Spacer in the coil?
    Adjustments to the Strut bar?
    Is the best way to measure "level" to measure ground to finder/wheel well? Or a level along on the sides of the chassis?
    Thanks for the help!
    Josh
  2. May 23, 2010 at 12:45 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
  3. May 23, 2010 at 12:47 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    Bilstein 5100s are your answer
  4. May 23, 2010 at 4:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Hi Josh, Welcome to TW.
    There are several options available. If you are only going up the 1" in front, a 1" lift spacer mounted on top of the compressed coil is a reasonably priced option and does not introduce too much pre-load into the spring. However, lift spacers are not always the best option because you might also compromise a little ride quality.
    The Bilsteins mentioned previously are another option as they provide a limited amount of adjust-ability at a moderate price point. With the 5100s you can set your lift at either .85", 1.75" or 2.5".
    Another option is adjustable coilover shocks which offer adjust-ability from 0" to 3". COs are the most expensive option.
    Curious about your truck. Is it actually a 4-door model Tacoma? Didn't realize there was a double cab model in 96.
  5. May 23, 2010 at 10:31 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    They did not make the double cab 1st gen's untill 2001 and thats also when the changed the front ends. So Idk why it says that lol.
  6. May 24, 2010 at 8:39 AM
    montanabay
    CA
    2.7L 4WD AUTO
    thanks for the help!
    yeah, its just the extended cab or access cab, must have clicked the wrong one.
    I think the Bilsteins will be a good options, since I need to replace the struts anyways I can kill two birds with one stone at a good price (~$90?).
  7. May 24, 2010 at 10:30 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    the only accurate way to measure is from the ground to the frame at each corner.
    in my opinion, however, 1" of rake doesn't look bad at all. ..makes it sit level when loaded.
  8. May 24, 2010 at 10:37 AM
    RPain
    RPain I drink, and I know things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    I've got the Bilsteins set at 2.5 and love it.
  9. May 25, 2010 at 11:35 AM
    montanabay
    CA
    2.7L 4WD AUTO
    Hi All,
    I can't find the 5100s locally for my truck, and each site I get a different part number....anyone know what will fit the truck?
    1996 2.7L Auto 4WD Tacoma, stock suspension.
    Thanks!
    Josh
  10. May 25, 2010 at 11:51 AM
    RPain
    Chandler, Arizona
    5100's are tough to find right now because they are in high demand but a low quantity supplied. My advice would be to check this site very often and wait for Down South Motorsports to get some more in stock. They offer discounts to TW members and have awesome customer service. I bought mine from them and it was well worth the wait. But check back often because they sold out last time in 2 days. Here's a link to the 5100's on their website. Bookmark it and check back often. ACTUALLY LOOKS LIKE THEY HAVE SOME IN STOCK NOW. JUMP ON IT. Discount Code - TACO9604F http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
  11. May 25, 2010 at 1:00 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Their 5100's don't show a 1.75" adjustable height anymore?
  12. May 25, 2010 at 1:13 PM
    RPain
    Chandler, Arizona
    All first gen bilsteins have the same settings. I think the 1.75 is a 2nd gen thing? Just set them at 2.5 its perfect.
  13. May 25, 2010 at 1:50 PM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    The only problem with the billies is that they limit your suspension travel because all your doing is pre-loading your spring. to get the most out of your suspension you should get a set of longer springs. ome makes a few different ones. and you should be able to use the 5100 if you so desire. just set them at 0" or preload.
    or go for the full ome setup. its a little more spendy then the 5100's but they are in stock...
    just my .02
    AD
  14. May 25, 2010 at 1:50 PM
    96er
    96er Sport Rally'er
    MA
    Yeah but at 2.5" am I starting to bind the front or looking at a diff drop or extended brake lines?
    And for the rear - a 1.5" wheeler's pack or AAL?
  15. May 25, 2010 at 2:22 PM
    RPain
    Chandler, Arizona
    As far as the front goes you don't have to worry about any of that unless you go over 3 inches
  16. May 30, 2010 at 10:12 AM
    montanabay
    CA
    2.7L 4WD AUTO
    Hi,
    Lets say I set all the billies to 0", then I want to haul a load, can I jack the rear shocks up to 1.5" and will that give be a better ride when loaded? I have leaf spring helpers (the 1/2 leaf bolt on type), which doesn't do much for my ride, so I'd like to ditch them if the billies can take their place when hauling.
    Thanks,
    Josh
  17. May 30, 2010 at 10:33 AM
    quattrokiwi
    Bruce
    Nor Cal
    the rear bilsteins aren't adjustable.
  18. May 31, 2010 at 4:21 AM
    AlexanderD
    Alex
    whitby Ontario
    yup rear shocks have nothing to do with your ride height. get some timbrens to make hauling better without screwing up your unloaded ride. they offer no lift though.
  19. May 31, 2010 at 10:14 AM
    RebelRider201
    RebelRider201 Well-Known Member
    J
    South, AL
    PreRunner
    5% tint, black emblem/grille/etc, 10k hids, Flowmaster super 44, Tuff Country 3", 1700w amp, Kicker L7 12.......and on
    I have the Tuff Country 2" leveling kit with their 3" AAL on the rear and clear 285/75 Nitto TG's with minor trimming and wheels with a 3.75 bs.
  20. May 31, 2010 at 10:26 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    They're not hard to find but what are you willing to pay? Yeah I know 3/4 guys here will say "down south motor sports' & thats fine if you don't mind waiting. & you will get a great price, but I wanted mine like right now, so a phone call placed & an hour later I had my 5100's out the door for $200.
