Proper way to rotate your tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by shankyjones, Sep 8, 2023.
  1. Sep 8, 2023 at 9:00 AM
    shankyjones
    shankyjones [OP] Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Guys I plan on doing this tomorrow so I need your help.
    Back in the day, the method was to use the criss cross, i.e. left front to right rear, right front to left rear. Left rear to left front, right rear to right front.
    It now seems like now the method is swap left front and left rear, right front with right rear.
    What method is the best in your opinion and why?
  2. Sep 8, 2023 at 9:04 AM
    Bishop84
    Bishop84 Well-Known Member
    Criss cross is best, but can induce vibrations as the tire wears into the new rotation, so best practice is taught, cross to rear, rear straight to front.
    I criss cross my own tires every time.
    Front to rear doesn't address shoulder feathering and it only gets worse with time, especially on trucks.
    Big problem is cross rotations are more of a pain at home without a hoist.
    Rock Lobster and shankyjones[OP] like this.
  3. Sep 8, 2023 at 9:12 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    That's my method, and yes, it's a pain in the butt. Loosen 24 lugs, put the truck on stands, front left tire moves under right rear bumper, then rear left tire fills the blank, front right tire fills the blank, rear right fills the blank, tire on ground gets put back on. Drop the truck and torque 24 lugs down.
    Bishop84[QUOTED] likes this.
  4. Sep 8, 2023 at 9:28 AM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I have a full size spare on the same wheel so I do the rearward cross. Having a 5th tire/wheel in the rotation actually makes it super easy.
    4WDKid and Slashaar like this.
  5. Sep 8, 2023 at 9:30 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    If you buy your tires at Discount Tire, they do the rotate and balance for free for the lifetime of the tires. So that's what I do.
    chuam likes this.
  6. Sep 8, 2023 at 9:32 AM
    chuam
    Marcus
    San Diego
    They'll do the rotation for free even if you didn't buy your tires there.
    Slashaar[QUOTED] likes this.
  7. Sep 8, 2023 at 10:10 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    This is true. However, my local DT is so busy its faster for me to drag the trailer out of my garage and dig out the stands and jacks than it is to book an appointment with them.
    'sides, I'm a fat bastard. I need the sweat. Same reason why I mow my own grass. :anonymous:
