Proportional valve leaking tips
Discussion in '1st Gen. Tacomas (1995-2004)' started by RpTacoma01, Sep 1, 2018.
  1. Sep 1, 2018 at 10:47 AM
    RpTacoma01
    RpTacoma01 [OP] Well-Known Member
    Raffael
    south florida
    2001 tacoma regular cab 4x4 2.7l
    3" lift, custom tube front bumper, American racing wheels, grappler tires.
    hey guys so I noticed that I was having to replace brake fluid once every few weeks and after the third time of topping off the master I thought I should look for a leak. I found it in the back of the truck coming from the proportional valve. Anyone know a cheap place to buy a replacement? Also I noticed with almost all of the replacements they don’t come with a new boot can you you the old one? If not what’s the part number to buy a new boot?
    Thanks again
  2. Sep 1, 2018 at 10:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Google "1st gen tacoma rear proportioning valve"
    You'll get sources and ideas about relocation, which may be something to consider.
  3. Sep 1, 2018 at 2:55 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I took mine off and took it all apart, cleaned it up and put it all back together,,, very clean,, can't stress that enough, and it is working fine and has for 3 or 4 years now. You can't buy a kit for it so you have to be careful,,,,, AND I could be totally wrong on this part but, it's a "pass" through for the fluid, it's not a dead end per se like a wheel cyl. or a caliper. I think this is the reason it's working, it doesn't see the terminal pressure,,,,, IMHO, could be wrong though but it was cheap enough and it didn't take that long. Not complicated and a just a few internal parts.
  4. Sep 1, 2018 at 7:56 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Apparently, there is a OEM kit of replacement boots for this valve.
    04477 BUSH & BOOT KIT, LOAD SENSING SPRING
    04477-60010 (01/1995 - 08/2000)
    04477-60040 (09/2000 - 08/2004)
  5. Sep 1, 2018 at 7:58 PM
    RpTacoma01
    Raffael
    south florida
    wow thanks guys for all the info
  6. Sep 1, 2018 at 9:56 PM
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    I can't tell what exactly is leaking in the picture.
    If it's a line that has bubbled and rusted through, then bend and flare a new line.
    If it's leaking at the fitting, then wrap the threads in teflon tape.
    If the actual valve is leaking from the body or some other catastrophic way, you could try soldering/brazing/welding it or just buy a new/used one.
  7. Sep 4, 2018 at 10:04 AM
    RpTacoma01
    Raffael
    south florida
    I think I’m gonna get a new one but do I need a new boot? Is the boot just a dust cover or does it have to be replaced.
  8. Sep 4, 2018 at 10:33 AM
    pulldo
    houston, texas
    It's a dust cover primairly, if it's not torn go for it.
  9. Sep 4, 2018 at 10:35 AM
    RpTacoma01
    Raffael
    south florida
    Is there any component it’s covering besides the prop valve? That I should also replace?
  10. Sep 4, 2018 at 12:55 PM
    RpTacoma01
    Raffael
    south florida
    Should I just order the replacement valve or is there other parts I should get?
  11. Sep 4, 2018 at 2:02 PM
    pulldo
    houston, texas
    There's a bunch of threads in the past on this, I was even in them and I don't remember that, but that's what happens when you're 70 yrs. old.
    I don't think they sell the guts for them, you'll have to pull it apart, I think and clean up the guts and reuse them, it's not that hard.
    Here's a kit I found, pretty cheap, but it appears to be just the boots and the bushing with mounting bolts, up to you if you want it or not,,, these are all external parts I believe.
    https://www.ebay.com/itm/0447760010...LOAD-SENSING-SPRING-04477-60010-/182398906476
    Make sure and adjust it to the FSM, if needed when you get it mounted back on the truck, and flush your whole brake system with new brake fluid every 2 to 3 yrs.
  12. Sep 4, 2018 at 3:39 PM
    RpTacoma01
    Raffael
    south florida
    Thank you for all the info. Very helpful sir.
