Proportioning valve crumbling and falling apart, need help with new part
Discussion in '1st Gen. Tacomas (1995-2004)' started by aemsfactory, Jul 17, 2020.
  1. Jul 17, 2020 at 8:59 AM
    aemsfactory
    aemsfactory [OP] Well-Known Member
    2001 Black Tacoma TRD w/ extra rust
  2. Jul 17, 2020 at 9:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    How's the frame :burp:
  3. Jul 17, 2020 at 9:05 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You park this thing in the ocean or something?
    For the love of god don't buy car parts from Amazon.
    Try something like car-part.com. There are a few others that are basically online wrecking yards. You can find a lot of used parts that were pulled from junkyard trucks.
    Honestly tho, I'd be more worried about the condition of your frame...
    jammer and Kwikvette like this.
  4. Jul 17, 2020 at 9:15 AM
    aemsfactory
    Not too bad but im going to be sand blasting and painting all of it.
    GQ7227 likes this.
  5. Jul 17, 2020 at 9:23 AM
    aemsfactory
    i just posted a few pictures. i doesn't look bad imo but im going to be sandblasting and painting
    GQ7227 likes this.
  6. Jul 17, 2020 at 9:27 AM
    jbrandt
    Justin
    I mean, I've seen worse, lol...
    The inside of the frame is usually the worst. So pay close attention to where the front leaf hangers are. If you can get a camera inside the frame to see, that'd be good.
    But even if your first pic, the frame is pealing. i.e. it's compromised. Once you remove all the rust and are comfortable with the inside of the frame, you might consider safeTcaps.
    https://www.autorust.com/product/all-tacoma-safetcap-kit-locations/
  7. Jul 17, 2020 at 9:54 AM
    aemsfactory
    took some more pictures
    IMG_20200717_113830397_HDR.jpg IMG_20200717_113845781.jpg IMG_20200717_114803784.jpg IMG_20200717_114810454.jpg IMG_20200717_114839454.jpg
    is there a good way to clean out the inside of the frame? and i found the part on car-parts.com
    GQ7227 likes this.
  8. Jul 17, 2020 at 9:59 AM
    jbrandt
    Justin
    Yeah, that's certainly not the worst I've seen, but that's not great either.
    There have been a lot of threads on frame rust and how to deal with it. Search around. Hopefully you'll find what you need.
  9. Jul 17, 2020 at 10:00 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :burp:
  10. Jul 17, 2020 at 10:01 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    oof i don't like some of that
    what part of the country are you located?
    i am using an air hose to clean out mine all the peeling garbage coating inside there
  11. Jul 17, 2020 at 10:04 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
  12. Jul 17, 2020 at 10:08 AM
    aemsfactory
    ok thanks for your help
  13. Jul 17, 2020 at 10:10 AM
    aemsfactory
    GQ7227[QUOTED] likes this.
  14. Jul 17, 2020 at 10:12 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    welcome to TW :hattip:
    i only learned about this bad frame stuff from TW a little over a year ago, never seen this bad stuff before, not ever!
  15. Jul 17, 2020 at 10:16 AM
    aemsfactory
    that's defiantly the worst spot, but with inspection from a hammer it sounds solid
  16. Jul 17, 2020 at 10:18 AM
    aemsfactory
    vehicle was in Wisconsin for 15 years, now in Illinois. but ill be living in the UP for college
  17. Jul 17, 2020 at 10:19 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i am on the other side of Iowa on Missouri river, so fairly close!
  18. Jul 17, 2020 at 10:23 AM
    aemsfactory
    whats your plan for the inside of the frame?
  19. Jul 17, 2020 at 10:25 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Don't bother replacing it. Just get rid of it
    you can bypass the valve completely and choose to add or not a manual one in its place. It's up to you really
    Upper line is the IN while the lower line is a return line that sends excess pressure and fluid back to the front brakes. Facing the differential is the OUT of the valve, where it connects to a rubber flex line that sends fluid to a splitter then to both wheels
    Connect the upper line (the line for the IN) to the rubber flex line (where the OUT connects to) and cancel the return line as it will no longer be needed. It comes from a splitter located inside driver's wheel well.
    If you want to add a valve:
    Get a 1 IN 1 OUT like this
    https://www.summitracing.com/parts/sum-g3905
    Install it next to the master cylinder. Line from the master going to the rear goes to the IN, then OUT goes to the rear wheels (where the original valve's OUT connects to the rubber flex line above the differential).
    joe25rs and cruiserguy like this.
  20. Jul 17, 2020 at 10:32 AM
    aemsfactory
    isnt is advantageous to have it though? if im hauling something i want more breaking power to go to the rear wheels.
