Propshaft Greasing Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adamant365, Mar 9, 2014.
  1. Mar 9, 2014 at 8:03 AM
    adamant365
    adamant365 [OP] Well-Known Member
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    Hi All,
    I'm about to go change the T-case and Diff oil as well as greasing the prop shaft for the first time. Okay, so all the nice how-to guides on here say to pump grease into the zerks until grease comes out clear. Okay, so my question is, where exactly does the old grease come out? I realize I'm forcing new grease in under pressure, but where should I look for the old grease to come out?
    Thanks!
    Adam
  2. Mar 9, 2014 at 8:07 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    It will come out from under the bearing caps. Depending on how tight your seals still are, you may not be able to pump them until it's clean. I can only get one and a half squeezes into mine and then it pressures up with almost none coming out
  3. Mar 9, 2014 at 8:10 AM
    adamant365
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    Great, thanks!
