Pros and cons about TRD supercharger
Discussion in 'Performance and Tuning' started by TRDSilverBullet, Mar 16, 2014.
  1. Mar 18, 2014 at 5:34 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Very Tru.
    Manuals spit clutches.....autos slip to death.....
    Course it is variable and can depend on many factors such as prior driving/towing habits, neglect, etc.
    Fwiw, I have a friend who's a toyota tech....
    While he was speaking to their support gurus about my trans possibly slipping, the higher ups told him that while unrelated.......
    The TUNDRAS with no more than a supercharger installed are expected to have slipping transmissions.
    Kinda crappy imho for the Tundy crowd, but Thats what I was told.
    Anyhow.... One must keep in mind that the toyota reflash for the Tacoma's can be hit/miss it SEEMS. Some run richer than others, and this MAY cause some to see more of a drop in mpg.
    Why did mine stay the same if I drive normally?
    I dont know.
    I can destroy a tank in no time if pushed.... But, I'm over all the scrubbing off rubber from my fender liners, exhaust, bumper, and so on.
  2. Mar 18, 2014 at 5:52 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Eh if you put a SC on a truck you should plan on some added protection...perhaps gears? sure, a Tundra can pull 40" tires no prob, but add a SC in the mix now it has to work even harder....
    Would there be much benefit to SC a Taco on 35" tires? Prob not, right?
    IMO I would only SC a modded rig if I had the additional funds to re-gear it and spare parts that may go out....stock Tundy or Taco? Sure, why not. ;)
  3. Mar 18, 2014 at 6:07 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Valve body is next....
    Its top of the list and should be done done this month
  4. Mar 18, 2014 at 7:11 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    OP, you will always lose a MPG's with a SC, however depending on how you drive, its not that big of a lose. Some ppl it might not even be noticeable.
    If you have a lead foot, MPG's will suffer even more :bananadead:
  5. Mar 18, 2014 at 8:47 PM
    T-Rex266
    Elon
  6. Mar 19, 2014 at 5:42 AM
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Even with the restraint of a Saint I can't do it... I've been trying to stay off boost to see what kind of mileage I'm going to get at best. Not gna happen, its to damn fun/ addicting!:D
  7. Mar 19, 2014 at 7:38 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    wait for it....
    Lol, I still havent cleaned mine off. :eek:
    and yeah, the flashes definitely seem to be inconsistent, but, tend to be on the rich side. I know mine seems to be runnin pretty damn rich.. :(
    .... This. :thumbsup:
  8. Mar 19, 2014 at 8:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If someone has an auto, and pushes it hard off-road, especially in the dunes, then the valve body upgrade is a must. If then they add an s/c, it should already be in the plans. Makes the clutch packs last longer.
    IPT can also build the auto transmission. DoubllD has had his built.
  9. Mar 20, 2014 at 12:26 AM
    2004Yotadtc
    2004Yotadtc Well-Known Member
    JAIME
    San Antonio
    2004 Pre Runner
    I wanna do my 3.4 don't do much off road would I need to replace my tranny only has 80k
    I have a pretty heavy foot also lol
  10. Mar 20, 2014 at 12:28 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    With a trans service you should be fine, the main thing is doing the maintenance on the trans to keep the oil from breaking down and not lubricating everything properly.
  11. Mar 20, 2014 at 12:42 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Who cares what the pros and con's are!!! Just bolt that puppy on get her flashed and then enjoy it.
  12. Mar 20, 2014 at 10:11 AM
    bowhun2r
    bowhun2r Well-Known Member
    Scott
    Steeler Nation
    19 - GX-460
    This may help a bit on the IPT valve job
    http://www.tacomaworld.com/forum/performance-tuning/318077-ipt-valve-body-finally-installed.html
    After driving it for about a month first gear engages very crisp.
    You can avoid it by very lightly going into the throttle.
    Still getting used to first gear engagement.
    Other than first gear it's been great.
    No lazy shifts during WOT. This will also help the longevity of the tranny.
  13. Mar 20, 2014 at 12:49 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    I'm just having a hard time believing that statement on the Tacoma. Could it be an optimistic figure? Maybe. But being realistic for the majority of the owners that do make the jump, majority loses MPG/economy. For the sake of it, that should be an understanding while deciding to do that upgrade.
    Driving characteristics and environment all play into factor. Here in AZ, i drive nothing but at 0 elevation, little to no humidity, ALL flat lands and on highway. Highway is all from 65-75mph. I find with the TRD S/C 1GR and the RPM range that the tacoma runs on 285/70/17's, it is in an inefficient band. I'm in a similar boat as Moose where I was at 330-350 miles to the tank on same tires, and now i barely make it to 280-300. Same driving behavior to and from work which is 99% of the mileage.
    Whereas my TRD S/C 2UZ 4Runner on 285/70/17's at <65mph stock TRD flash, efficiency was terrible. I made a log sheet of 1 month of driving <65mph vs 1 month at 65-75mph at improved mileage. Point being that there is an efficiency range where 1 vehicle may get better mileage than another, which the Tacoma I find does not.
  14. Mar 20, 2014 at 12:52 PM
    signalbobby
    Robert
    Arizona
    18 Rapturd
    I'm not calling anyone anything, just stating my opinions. To each his own. As I said in the post above, just having a hard time believing it. But this is the forum so if i offended you, i apologize.
  15. Mar 20, 2014 at 2:09 PM
    #35
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :spy:
    yup.. took me awhile to get used to it engaging that first gear.. and shifting into reverse. people still ask when they ride in my truck "woah.. your tranny supposed to be like that?" lol
    I love it.. have had it for 2 or 3 months now.. and as you stated.. easy throttle into that first gear change it isnt so bad.. the rest are great.. pulls hard :)
    I hear ya man.. im jealous of your 280-300 miles on a tank tho.. im trying to take it easy this tank.. aired up the tires to around 40psi.. easy slow take offs, etc. we will see.
    regardless.. still so worth it :D
  16. Mar 20, 2014 at 2:11 PM
    #36
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Con = expensive
    Pro = you will go faster
  17. Mar 24, 2014 at 8:55 AM
    #37
    TRDSilverBullet
    TRDSilverBullet [OP] Active Member
    Chase
    North Carolina
    2007 toyota tacoma "silver bullet"
    Leveling kit, xd series monsters, magnaflow exhaust, aem cold air intake, jet chip and jdm chip
    And if I'm getting a supercharger do I need a one piece drive shaft ?
  18. Mar 24, 2014 at 9:45 AM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Mar 24, 2014 at 9:47 AM
    #39
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup: This :D
    being able to easily swap the filter is worth it on its own.
    also.. to add to the pros.. wheeling!
    it was so nice this past weekend on our 35+ mile trail run with the extra torque. easily climbing hills, not constantly trying to pick a gear, etc. made me fall in love with the truck all over again. :D
  20. Mar 24, 2014 at 7:07 PM
    #40
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Fixed it for ya :)
