Pros and cons about TRD supercharger
Discussion in 'Performance and Tuning' started by TRDSilverBullet, Mar 16, 2014.
  1. Apr 9, 2014 at 1:33 PM
    #61
    dsjones5
    dsjones5 Well-Known Member
    DSJ
    Georgia
    2011 MG DC Taco
    Seat covers, weather tech digi fit, bug deflector, plasti dip wheels, magnaflow muffler, and many more to come!.. as soon as i get money. Ill probably go broke typing this...
    Pros: You feel as if jesus is riding shotgun with you.
    Con: Jesus will tell you drive faster than legal speed limit.
    Conclusion... Jesus is a straight boss.
    He would drive a tacoma. A supercharged tacoma.
  2. Apr 9, 2014 at 5:44 PM
    #62
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Still lovin my supercharger.. still hating my gas mileage... but.. did I mention I'm still loving my supercharger?! :D
  3. Apr 9, 2014 at 6:53 PM
    #63
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    $4 a gallon..239 miles per tank equals a fuckin' rush that never gets old....
    who gives a shit if you have to pull into every other gas station....:D
  4. Apr 9, 2014 at 9:19 PM
    #64
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This.. :D
  5. Apr 11, 2014 at 1:53 PM
    #65
    TRDSilverBullet
    TRDSilverBullet [OP] Active Member
    Chase
    North Carolina
    2007 toyota tacoma "silver bullet"
    Leveling kit, xd series monsters, magnaflow exhaust, aem cold air intake, jet chip and jdm chip
    do I need to build the transmission, rear end, drive shaft? Because the supercharger voids the warranty
  6. Apr 11, 2014 at 2:09 PM
    #66
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    IIRC if you install it 12mo/12k warranty. If Toyota installs your warranty remains the same? Man I would like to install one but maybe save the go fast $$ for a 335 or 5.0 stang?
  7. Apr 11, 2014 at 2:45 PM
    #67
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    ^^^Correct, factory warranty with dealership install..
  8. Apr 11, 2014 at 4:47 PM
    #68
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I bet the spacers and chips u have are more dangerous than the blower.
    Btw how does your JDM chip work along with the jet chip?
  9. Apr 11, 2014 at 5:52 PM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :rimshot:
  10. Apr 11, 2014 at 5:56 PM
    #70
    keninsb
    keninsb "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    I was reading the installation instructions for the SC and noticed one CON right off the bat, page one 2nd column. You need to re-flash the ECU when the SC is installed, but according to the install instructions the re-flashing cannot be undone. In other words, once you install the SC, it has to stay on or you have to get a new ECU! That is kind of a bummer.
    HERE is a link to the install instructions thanks to Tim at TRD Sparks Toyota (man I wish they were my local dealership!).
    This almost makes the URD UCON that Justus mentioned in a thread worth it right off the bat, but then there is that pesky warranty thingy again :(
    Still pretty jazzed about getting the SC installed though...
    Ken
  11. Apr 11, 2014 at 6:22 PM
    #71
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    somebody say jdm chips?
  12. Apr 11, 2014 at 6:23 PM
    #72
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For you Keninsb, you current option are the reflash or a wire in aftermarket EMS. No UCON, since it is plug n play only and its plugs don't fit your plugs.
  13. Apr 11, 2014 at 6:26 PM
    #73
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Racecouch ftw
  14. Apr 11, 2014 at 6:28 PM
    #74
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Japan's ambiguously gay duo. Lol
  15. Apr 11, 2014 at 7:30 PM
    #75
    keninsb
    Ken
    Goleta, CA
    LMFAO!!!!!!
  16. Apr 12, 2014 at 5:44 AM
    #76
    TRDSilverBullet
    Chase
    North Carolina
    It does good
  17. Apr 12, 2014 at 10:14 AM
    #77
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    lol :thumbsup:
  18. Apr 12, 2014 at 10:31 AM
    #78
    Lindsey Walrod
    Lindsey Walrod Well-Known Member
    Lindsey
    Oregon
    '13 black beauty
  19. Apr 12, 2014 at 11:44 AM
    #79
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    No no.. I meant literally, how do they work together?
    Does 1 control the other, or are they work independently?
    And how hard were they to tune?
  20. Apr 12, 2014 at 9:31 PM
    #80
    TRDSilverBullet
    Chase
    North Carolina
    They work together
