Pros and Cons OEM options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma/Taco, Aug 5, 2020.
  1. Aug 5, 2020 at 8:01 PM
    Tacoma/Taco
    Tacoma/Taco [OP] Well-Known Member
    Josh
    Southern Maine
    Tacoma13'build in process
    3inKing coilover with clickerreservoirs 600lb King struts clicker reservoirs Total choas UCA Total choas Race series LCA Total choas bed stiffnners Timberland bump stops front/rear Welded gusset All pro aluminum apex bumper Warn 9000 Pia fog lights Pia off road light led Baja light bar Spider projection lights U bolt flip kit All pro 3in expedition leafs ARB front & rear locker ARB twin compresser Large ARB tank 4:56 gear ratio CBI slider bolt on CBI rear bumper steal Marlin crawler Taco Box 4:7 Optima blue top BFG 285/75R17 mud tires Body mount chop 1.25 wheel spacer Budbuilt Full body armor with crossmember support for dual transfer case skid plate Redirected exhaust Spider headlights warn Synthetic winch line Factor 55 fairlead Fiberglass hood, front-rear fender wells Beaded rims Spare tire mount in bed
    Hi everyone, I’m planning on buying a 2016 to 2017 Tacoma, V6, 4x4, in Automatic. All options other then mentioned above and models are up in the air. Down the road I plan on adding a cap, AT tires and tons of lights... What are the pros and cons of certain options you picked on your Tacoma’s?
    Thanks
    Josh
  2. Aug 5, 2020 at 8:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It probably already has a cab...
