Pros and cons of a sway bar?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck93, Nov 19, 2017.
  1. Nov 19, 2017 at 1:17 PM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    I recently lifted my truck 2 inches and I was wondering if I should get rid of my sway bar or keep it connected. What are the pros and cons of not having one.
  2. Nov 19, 2017 at 1:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Pro's better for actual Off Roading, Con's not a good idea if it is a daily driver and used back and forth on the highway and such
    DrFunker likes this.
  3. Nov 19, 2017 at 1:19 PM
    DrFunker
    DrFunker Well-Known Member
    Off - better for off road. More body roll.
    On - tighter control esp. in corners. Better control in aggressive maneuvering.
  4. Nov 19, 2017 at 2:08 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  5. Nov 19, 2017 at 2:27 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    You will find lots of threads on this topic just by google searching tacomaworld.com sway bars
    Here's a few..https://www.google.com/url?sa=t&sou...SBigQFggmMAA&usg=AOvVaw36qPTnCJ_rZ-gb3cXYH4xR
    https://www.google.com/url?sa=t&sou...VCg0QFggmMAA&usg=AOvVaw09j66zLH7-Spw9OjAL77_N
    I'll let you find the rest:thumbsup:
    :hattip:
  6. Nov 19, 2017 at 2:33 PM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    If you remove it with your factory coilovers, yes, you will certainly notice a significant amount of body rolls especially around corners and also during sudden stops at high speeds.
    HOWEVER, if you have good quality coilovers with stiffer spring rates, you will not notice a difference when removing the sway bar. When I installed IVD coilovers, I finally removed my sway bar permanently and did not notice a difference at all.
  7. Nov 19, 2017 at 2:43 PM
    tacotruck93
    Zach
    Akron,Ohio
    I have 5100 all around with 886 OME could
  8. Nov 19, 2017 at 2:48 PM
    inwood customs
    Dave
    Yes?
    But maybe no
  9. Nov 19, 2017 at 2:49 PM
    inwood customs
    Dave
    5100 and eibachs... 5yrs
    Still alive
  10. Nov 19, 2017 at 2:51 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Remove it you’ll have a better ride all around won’t be so bouncy on off camber roads. If you don’t like the way it drives slap it back on not to hard. If you tow frequently I’d suggest leaving it though. Took mine off after having my coil overs for 3 months an wish I had done it sooner.
    jeff b likes this.
  11. Nov 19, 2017 at 5:20 PM
    Pigpen
    Dan
    Northwest Montana
    I have 5100s with 885 coils - softer than your coils. Haven't had a sway on for a couple years. Happy with my decision.
  12. Nov 19, 2017 at 5:58 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    Tempted. Not a daily driver. Maybe twice a week for local trips to the store. Bilstein 5100s and 887s. Feedback appreciated.
  13. Nov 19, 2017 at 8:37 PM
    Pigpen
    Dan
    Northwest Montana
    If you wheel it much, or very hard. Pull it and see what you think. If not. Leave it on.
  14. Nov 19, 2017 at 9:15 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    always had this debate as well... maybe ill pull it someday
  15. Nov 19, 2017 at 9:25 PM
    tacotruck93
    Zach
    Akron,Ohio
    I did the 886 OME coils up front for to handle the added weight when i put the bumper and winch. As of right now they had a the lift kit on for about 1,000 miles and im very happy with it. The ride quality is amazing.
  16. Nov 19, 2017 at 10:42 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    Pros:
    More down travel
    Front end feels softer
    Weight reduction
    Cons:
    Body roll
    Annoying to drive on freeway/at high speed
    Taco lean
    That being said mine is sitting in the garage and I’m ok with that
    DrFunker and tacotruck93[OP] like this.
  17. Nov 19, 2017 at 10:51 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    :notsure:
    Proof that you have to try it to make your own opinions.
  18. Nov 19, 2017 at 10:53 PM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Just re-read it and I mixed myself up, @DrFunker agreed :rofl::rofl::rofl:
    EatSleepTacos and DrFunker like this.
  19. Nov 19, 2017 at 10:54 PM
    tacotruck93
    Zach
    Akron,Ohio
    very true! Well seems like I have a fun weekend project. Ill give it a week and see how i like it my drive to work is only 10 minutes so it shouldn't be that bad.
  20. Nov 19, 2017 at 11:08 PM
    tacotruck93
    Zach
    Akron,Ohio
