Pros and Cons of Load Range E Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voos, Mar 10, 2015.
  1. Mar 11, 2015 at 9:25 AM
    drscott11
    drscott11 Well-Known Member
    I went with R & B rated and no I don't mean James Brown.
  2. Mar 11, 2015 at 9:29 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Give them a try. I really try to stick with load range C, but maybe you won't mind the decrease in mileage and the rougher ride.
    If you really use your truck hard, you may like the benefit of load range E tires.
  3. Mar 11, 2015 at 10:59 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    LT245/75R16 Load Range E Michelin LTX A/T 2 because they're tough little buggers that still get good mileage and are super stable for towing. :)
  4. Mar 11, 2015 at 11:55 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    I really wish there were more d range large agressive tires. I am sure the full size truck owners would like them too... those that dont pull 8000+ lbs. Better gas mileage and smoother ride would be nice... I have 34" BFG KOs now on 20" rims and it takes a lotta power from my ride. Looking at duratracs because there is a 33" SL load tire that weighs 11 lbs less per tire. My only concern is shredding that sidewall when i pull my 4000 lb boat. But the tire is SUPPOSED to be able to handle that... maybe well see.
  5. Mar 11, 2015 at 12:32 PM
    JasonU71
    JasonU71 Well-Known Member
    displaced in Southern Maryland
    2015 TRD Sport
    Icon Extended Coilovers, Camburg Ball Joint UCA, Icon 2.0 rears, Wheelers 3 leaf AAL, WeatherTech mats, ARB Front Bumper, IPF Dual Beam lights, JBL amp and speakers
    Just put a set of 265/75/16 BFG KO's ($670 for 4 @ Tire Buyer) on my Tacoma and have not noticed a harsh ride. I think when it comes to tires, the inflation pressure has a lot more to do with the ride quality than the load range.
    I'll also say that this Tacoma rides pretty plush in comparison to the Dodge Cummins 2500 4x4 that I traded in. Maybe I'm just not as sensitive to the subtleties of off road tires.
  6. Mar 11, 2015 at 12:36 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Pro:
    Tougher sidewall
    More load weight capacity for hauling
    Cons:
    Ride hard and stiffer than C
    Harder to run low pressure in the desert or rocks due to not flattening out enough
    heavier so you might lose power and mpg.
    I went from an E rated BFG all terrain then E rated BFG mud terrain to now a C rated Duratrac.
    I gained better floatation in sand, smoother ride and gained back my lost 1-2 mpg from the old tires.
  7. Mar 11, 2015 at 1:00 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    1.5 mpg is worth several hundred dollars a year for the average driver. They could be posing at the mall with cool looking Duratracs plus a new light bar. :)
    Alta23 likes this.
  8. Mar 11, 2015 at 1:45 PM
    JasonU71
    2015 TRD Sport
    I may also be insensitive to fuel mileage, because of my previous 3/4 diesel.
    If you drive 20k per year at 18 mpg you total fuel costs equal $2711.11.
    That same 20K at 16 mpg will set you back $3050.00.
    The yearly cost difference of 2 mpg is $338.89, this may buy you an inexpensive light bar, but remember those load range C Duratrac's are going to cost you more initially.
    These figures used todays national average $2.44 a gallon fuel price for regular unleaded.
    $338.89 over the course of the year equates to $6.52 a week. If things ever get this tight for me I'll have more to worry about then modding my truck.... lol
  9. Mar 11, 2015 at 2:21 PM
    hamburglar
    hamburglar Swollen Member
    Oregon
    Taco Supreme
    many
    265/75/16 Good year silent armor pro grade (10 ply) E
    A few years on the truck, ~40k miles, still very satisfied. These can really take a beating. Also they have been much better in most all weather conditions than prevous Toyo MTs. Those were loud and poor traction when wet, meant for rusted out chevys.
    Ride is a bit stiffer partly because I have them aired to nearly 50psi.
  10. Mar 11, 2015 at 2:30 PM
    hamburglar
    Oregon
    Taco Supreme
    many
    I'll probably get a lighter All Terrain set for the next round.
  11. Mar 11, 2015 at 2:42 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    E FTW! Drive over stuff and don't worry. Just put 35-ish psi in them and be done. Gas is cheap, burn more!
  12. Mar 11, 2015 at 3:05 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I must be desensitized to tire effects.
    I didn't notice any difference in ride between the OEM tires, my Load Range "E" BFG ATs and my Hankook snow tires. I don't analyze my MPG outside of watching my ScanGauge but I didn't notice all that much difference between the two.
    Then again I've grown up on lowered cars, stiff suspension and wide tires, so my truck feels cushy by comparison.
  13. Mar 11, 2015 at 3:22 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    In my experience the gas mileage penalty is small. I am on my second set of load range E tires and still get better mileage than most post here--typically 25 mpg +.
  14. Mar 13, 2015 at 9:06 AM
    jgang
    jgang Well-Known Member
    I compromised the tire size by going with a Cooper AT3 in 275/70/17 in load range C. Only very minor trimming up front (30 seconds a side), bigger than stock, no lift, great fit and looks great on a set of 6 spoke 4Runner rims. Mileage is 17ish around town with 19s on the highway. I had a set of BFGs in load range E for about 20 miles.....way overkill on 98% of the Tacomas out there although the dedicated off road benefits can't be denied for serious wheelers. "C" is where it's at for me an my Taco....
  15. Mar 13, 2015 at 9:57 AM
    #35
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
  16. Mar 13, 2015 at 11:13 AM
    #36
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Hated the ride in my old BFG KO E-load range. Look great, but super hard and completely un-needed for what I used them for. I would look for something else unless you really need that extra ply, weight, etc...
  17. Mar 13, 2015 at 1:41 PM
    #37
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    Does anyone even make a 275/70r/17 load c tire? All I'm finding are E rated.
  18. Mar 13, 2015 at 2:00 PM
    #38
    jgang
    Yep. Cooper Discoverer AT3. Both in E and C load ranges. Fabulous tire. I'll be buying another set later this year unless the reviews on the new BFG AT KOs are through the roof. The AT3s are the best tires I've ever owned. Currently around 45K on them and probably another 10-12K left in the tread.
  19. Mar 13, 2015 at 2:03 PM
    #39
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Horrible idea to have 10 ply tires. I did it once and never again, not worth the money and loss of mpg's. They did last forever though but the ride sucked ass...never ever ever ever again :)
  20. Mar 13, 2015 at 2:11 PM
    #40
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Any with a more aggressive tread? Or is that really the only one that's load C?
