Pros and Cons of Load Range E Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voos, Mar 10, 2015.
  1. Mar 13, 2015 at 7:14 PM
    #41
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  2. Mar 13, 2015 at 7:57 PM
    #42
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
  3. Mar 13, 2015 at 8:34 PM
    #43
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Since currently running Duratracs after using BFG AT KO and BFG MT tires, I will continue to give GoodYear my money.
  4. Mar 13, 2015 at 8:40 PM
    #44
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    What load are you running?
  5. Mar 13, 2015 at 9:12 PM
    #45
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    C All the BFG I ran were E rated
  6. Mar 13, 2015 at 9:16 PM
    #46
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    E Rated is beyond over kill on daily driven trucks in our weight class.
    Sure sometimes its all thats offered in an over sized option by brand however if given the chance to chose unless I plan to do 75%+ off road C is better.
  7. Mar 13, 2015 at 10:31 PM
    #47
    KBKB
    KBKB Active Member
    I recently had this same dilemma and, in my opinion, the best 285-75-16 D load that I found was Cooper Discoverer ST (not stt or maxx). But I was also able to get a discount on Toyo ATII (load e). If I remember right, the weight difference was only 2 or 3 lbs per tire. So I figured there wouldn't be enough of a difference not to go with the discount. That being said, I definitely feel the road with the 'E' load range.
    Also, for some reason, Toyo ATII 285-70-17s come in either range B or E.
    W(hy)TF not C or E. Save us all some headaches, for those that like Toyo
  8. Mar 13, 2015 at 10:58 PM
    #48
    TSJESME
    TSJESME Well-Known Member
    James
    Maui
    14 TRD SPORT A/C 4X4 M/T
    I have the Goodyear Adventure/Kevlar A/T's this time around, bought in January.
    Previously mentioned tire on the 07, were the Silent Armor.
    I can agree that a "D" rated tire is really the perfect weight/ durability for the Tacoma, just hard to find.
    I like my ""E" tires, but I do feel the weight.
  9. Mar 14, 2015 at 12:18 AM
    #49
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Personally I believe e rated tires and 3ply sisewalls to be the only option for on and off road use. I can say I've experienced 0 cons to using e tires in fact they're probably the only reason I haven't had to replace every tire on my truck. It does depend on your local terrain however and how comfortable you feel with potential for having to run on your spare. at the end of the day it's up to you but I say be over prepared
  10. Mar 14, 2015 at 12:18 PM
    #50
    comatosed
    comatosed Well-Known Member
    Central Florida
    Silver TRD Sport
    TRD roof rack, Roof Basket, Weather Tech liners, Wet Okole seat covers, bed mat, AFE Pro Dry Filter, Eclipse AVN726E dvd/nav, kicker door speakers, 8" kicker sub & amp, fox 2.0 coil overs, moab 2.0 front bumper, Full CBI Skid Set, CBI Offroad rear Bumper, CBI Sliders, BFG AT KO 2, Leer Topper setup for camping. Other mods-full synthetic, carbon filter, de-badged, center console lock.
    I got the same tires in E since I sometimes haul around 1 ton in my truck not including a trailer. They ride a little more rough but not bad, the wear is great, and I lost about 1.5mpg going from factory tires/size to slightly bigger. The other beautiful thing is they are durable as hell. I've pulled nails out and not had to patch the tire.
  11. Mar 14, 2015 at 5:31 PM
    #51
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I run E rated because P wasn't enough and the tire I wanted wasn't available in C or D. I bought Michelin MS2 for summer and Cooper ATw for winter. Both are great and neither provides an uncomfortable ride. I get about 18mpg combined. I think the sidewalls on C D and E tires are always the same. Only the tread pattern area is thicker. I don't imagine there's a huge weight difference.
    I have a slide-in camper so I wanted stiffer sidewalls. Even without the camper I don't want to run P rated tires because in my experience and where I drive, those things are always springing leaks.
  12. Mar 14, 2015 at 11:38 PM
    #52
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Im not a tire guru but think load range E tires either have a third sidewall ply (historic definition) or a heavier sidewall equivalent to a tire with the third ply (modern definition).
  13. Mar 15, 2015 at 3:10 AM
    #53
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    I'm not a tire guru either but this is what I've been told. When trying to decide between 6 8 or 10 ply Toyo AT's for a work rig (Tahoe) the owner of the shop told me they all have the same sidewalls. LT's have LT sidewalls and P rated have P rated sidewalls. Only difference in 6 8 or 10 (C, D or E) is the number of layers under the tread. Thus the minor differences in weight.
