Pros and cons of moving to 17" wheels
Discussion in 'Wheels & Tires' started by TacoBomba, Aug 1, 2023.
  1. Aug 1, 2023 at 3:31 PM
    TacoBomba
    TacoBomba [OP] Well-Known Member
    Will
    Maryland
    23 TRD OR Lunar Rock
    So I am trying to figure out what I want to do with my OR wheels. It seems a lot of what I like aren't really available in 16". Are there any big reasons to or not to move up to 17". This is a mostly daily with some trail use nothing crazy. I do like the scs Ray10 but they dont have 16s. I also like the black trd pro 17s.
  2. Aug 1, 2023 at 3:33 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    My only advise is: If you spend money, spend it on things that will give you performance(beadgrip, beadlock, bead studs and the proper offset) and not only looks. Size it’s up to you. Cheers!
    TacoBomba[OP] likes this.
  3. Aug 1, 2023 at 3:36 PM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    Unless your really wheelin hard with low tire pressure 16” vs 17” is negligible.
    I went to the TRD pro 17” wheels to have more 255 tire options. So far so good!
    DavesTaco68 and TacoBomba[OP] like this.
  4. Aug 1, 2023 at 3:41 PM
    EL DUDE
    EL DUDE Well-Known Member
    No pros or cons. Just buy what you want. Price differences are negligible
    ToyoTaco25 and TacoBomba[OP] like this.
  5. Aug 1, 2023 at 3:44 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    I run 16s on my 35s and I wish I'd run 17s.
    There's really no difference performance wise between 16 and 17 -- the tread is negligble -- but a) 17s have more size options and b) big brake upgrade kits require 17s minimum (except for the SOS performance kit on their smaller rotors but 17s would still be better).
  6. Aug 1, 2023 at 3:56 PM
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    Like other have stated, if you look at what size wheels are coming on the newer vehicles, you will see that the trends are not sticking with 16” overall. The larger disc brakes are necessitating a larger wheel to accommodate these new models. You will still find some good 16” options, but you might not find your new favorite tire in the 16” option.
    There are some unique sizing options that you might or might not be interested in that are only offered in 17” wheels. The 285/75/17 or 34” comes to mind. But you should consider width because if you pick too wide a wheel, you might option yourself out of the tall/skinny tire options.
    It really comes down to what you want to be doing with your taco. Figure that out, and it will make your path a little clearer.
  7. Aug 1, 2023 at 4:48 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    We do offer the Ray10 in a 16x8 -12mm spec. They'll be back in stock soon.
  8. Aug 1, 2023 at 4:51 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I like 17’s because of the 255/75 and 265/70 options. I also think 17’s are just right for aesthetics. Really it all comes down to personal preference. On stock or near stock size tires, you won’t be doing enough wheeling for sidewall to matter.
  9. Aug 1, 2023 at 5:02 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Much better options for tires on 17's. I just got some new wheels to fit the 35x10.5 tires, but even if you don't want to go that big there are options for C load or SL load tires in 285/70-75 to keep things light. It seems like most of the larger tires available in 16's were E load.
  10. Aug 2, 2023 at 11:40 AM
    cowfootball
    2022 TRD OR
    If you're running 35s I can't imagine why you wouldn't want E, though.
  11. Aug 2, 2023 at 11:43 AM
    BabyBilly
    Billy
    2020 TRD
    I'm not, I've got e-load K02's 285/75r16 now. Got some 35x10.5 d-load in the basement to go on 17" rims soon.
  12. Aug 2, 2023 at 11:48 AM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    17 tires are easier to find in case you need a replacement in a small town
