Pros and cons of using a bed mat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mperl, Jun 16, 2018.
  1. Jun 16, 2018 at 2:56 PM
    mperl
    mperl [OP] Well-Known Member
    Texas
    Impulse Red 2006 PreRunner SR5 TRD Quad Cab
    Do you use one? Does the rubber bed mat help or hinder?
  2. Jun 16, 2018 at 2:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
    Wouldn't do w/o it as it keeps sliding stuff to a minimum.
    I periodically remove it. Like for hauling a 200# box to the shipper.
    That needs to slide easy so the wife can move it with less effort.
  3. Jun 16, 2018 at 3:00 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    yes & yes
  4. Jun 16, 2018 at 3:01 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Actually a good answer. Hard to slide stuff into the bed but it’s good protection if you care about that. As others have said, it also reduces shit sliding around to a minimum.
    scottalot likes this.
  5. Jun 16, 2018 at 3:19 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    This.
    I keep mine in the bed unless its a heavy item that needs to slide. I picked up a 270lb toolbox months ago (boxed up), and had to unload by myself.
    I had left the bedmat on my garage floor before i picked up the toolbox (loaded by 3 ppl). Got home, backed truck into garage, moved bedmat under tailgate, slid the box to the end of the tailgate (easy peasy).... made a pulley system out of a cpl tiedowns and bedrail cleats, and lowered the toolbox onto bedmat on garage floor, moved truck, put on casters, locked em, then tipped toolbox onto its wheels.
    The bedmat has a time and place.
  6. Jun 16, 2018 at 4:11 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I can't believe I went 11 years without one. One of the best 90 bucks I have ever spent.
  7. Jun 16, 2018 at 4:18 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    IMO, a bed mat is one of those must-have items.
    TacomaMike37 likes this.
  8. Jun 16, 2018 at 4:21 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Agree with those above. The only negative I can think of is when you need to slide a heavy item into the bed. The mat is pretty tacky so it won't allow sliding (as is its purpose).
  9. Jun 16, 2018 at 4:28 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    I cut my own out of a stall mat before I bought a bed-rug. Would highly suggest putting something back there tho! Saves your bed as well as your items from being thrown about!
  10. Jun 16, 2018 at 4:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I have had mine in since the first week i have had my truck. almost 5 years. NEVER ONCE have I felt like damn this is annoying and wanted to remove it. Every truck should come with one IMO.
    Get one you wont regret it.
    I also took the time to get a lil carriage bolt and washer to run topside down through the middle front bed drain hole and captured with a wing nut on the bottom side of the bed. This makes it to where you cant walk by and pick it up out of my bed, also keeps the mat from sliding out of the truck when using the front brake of my dirtbike when unloading.
    msfit likes this.
  11. Jun 16, 2018 at 5:00 PM
    Rollingstoned
    Rollingstoned Well-Known Member
    First thing i purchased for my 2012 taco was a bed mat, definetly a must
    You will not regret it
  12. Jun 16, 2018 at 5:10 PM
    Kotah
    Kotah Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    Wouldnt be without the bed mat, if it needs to come out for some reason all about 5 seconds to remove it,
  13. Jun 16, 2018 at 6:46 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Pro: Stuff won't slide
    Con: Stuff you want to slide won't
  14. Jun 16, 2018 at 7:00 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    This^^^
  15. Jun 16, 2018 at 7:06 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    First thing I added to the truck. Nothing slides.
  16. Jun 16, 2018 at 7:33 PM
    mperl
    Texas
    Excellent replies. Convinced. Buying one now.
    Blockhead, CMD-KY and ChadsPride like this.
  17. Jun 16, 2018 at 7:43 PM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Love mine. Debated on it for about 2 years, then seen a group buy on here and figured id give it a shot, if i didnt like it would resell it.
    Now i dunno how i went without it. Its a lifesaver man, just every now and then i take it out and wash it and the bed, i hail alot of debre from some property im clearing out, so i need to clean it all. But you definitly wont regret it.
  18. Jun 16, 2018 at 8:11 PM
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    This was one of the first things I bought after getting my Tacoma. Love it. Cleaning it is super easy too.
  19. Jun 16, 2018 at 8:15 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Only 1 con for me, weighs 25 lbs. Also blocks exhaust noise a little. I've had several over several trucks, very useful.
    BillsSR5 likes this.
  20. Jun 16, 2018 at 8:21 PM
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    ^ This. But there's a lot more times I don't want stuff to slide. A must have, money well spent item.
