Pro's Con's of a 3" or 6" lift
Discussion in 'Suspension' started by NiceTaco, Nov 25, 2008.
What lift do you prefer
  1. 6 inch
    293 vote(s)
    23.5%
  2. 3 inch
    953 vote(s)
    76.5%
  1. Nov 25, 2008 at 5:24 PM
    NiceTaco
    NiceTaco [OP] Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    What are the pros, cons to lifting your taco (Cost aside)
    are there any issues that are common after either of these lifts ( i havent decided on a 6 or 3")
    with 6" will things wear faster, more unstable??
    Does it make sense to lift it 6" if your not wheeling it i mean i will a little but not hardcore
    im not sure 3" looks high enough for me
  2. Nov 25, 2008 at 5:39 PM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
    i think 3" with 33's is a great look......no since in anything bigger, unless you're offroading...........my opinion
  3. Nov 25, 2008 at 5:42 PM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    if you're not gonna wheel it, go 6" with 35s it looks way better,
    if your going to wheel it go Total Chaos LT with custom 4" springs in the back
  4. Nov 25, 2008 at 6:13 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I like the 4"
  5. Nov 25, 2008 at 6:23 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Who makes a 4"
  6. Nov 25, 2008 at 6:59 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Total Chaos has a LT setup and Pure Performace has a kit they claim as 4" too.:cool:
    Pros 6"- More room for a bigger tire
    Cons 6"- have to cut cross member, you dont gain any ground clearance under the crossmember except from the tires, increases angle of rear drive shaft, 35's are gonna be big unless you re-gear
    Pros 3"- (cost) easier to get in, gives increased clearance under crossmember+ the clearance from larger tires, less work to install
    Cons 3"- Cant fit 35's, increase angle on front CV shafts
  7. Nov 25, 2008 at 7:02 PM
    RelentlessFab
    Eric
    Sparks, NV
    All in all, i'd like to get a 6" Fabtech basic lift and run some Bilstein 5100's under the front at the .85" lift to get about 7" total and then add some 35's..... all for the offroad, looks, and cost perspectives.
  8. Nov 26, 2008 at 7:41 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    no point to LT if you don't live/wheel in a region where you would need it...
    what kind of terrain are you in?
    is this strictly for looking hot for the girls?
    also a drop bracket lift does not have significantly more ground clearance than a 3" IFS lift as the brackets can get caught up on rocks anyway...
  9. Nov 26, 2008 at 7:52 AM
    SilverSeven
    Jordon
    South Jurzee
    LT can be useful in any terrain
    6" between the tires is little over stock depending on how high you crank coilovers, between axles, it is far superior
  10. Nov 26, 2008 at 12:06 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    3" susp. lift with 3" body lift(only if you dont 2 wheel your shit) and 33's
  11. Nov 26, 2008 at 3:06 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    what to you mean 2 wheel my shit........
    also its not for getting girls..have one..maybe a bigger lift would loose her...:DJ/K
    My terrain is all over im in Canada i live in Toronto, but do head up north often..so i need a practical lift for city driving that looks good but will also be effective when i go up north to get dirty!!
  12. Nov 26, 2008 at 3:12 PM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Saw this bumper sticker once... "Lift it. Fat chicks can't jump."
  13. Nov 26, 2008 at 5:39 PM
    paintdiddy
    shithead
    silver bullet
    i meant if you dont 4 wheel the truck
  14. Nov 27, 2008 at 12:49 PM
    BigToy
    BigToy Member
    Hawaii
    08 Tacoma
    6" Fabtech, 3" body, 35"s on 17"s
    Even with a 6" lift, 35's on a 9" wide rim will not fit without major trimming. I have (Fabtech) 9" of lift and still have to trim the bracket for the body mount right behind the front tires, and the lower rear section of the fender. I know Fabtech claims you can run 35's with their 6" lift, but take my word for it, you will have very little clearance.
  15. Nov 28, 2008 at 1:30 PM
    dabighi
    dabighi Well-Known Member
    can you run either the camburg or total chaos spindes with extended frnt struts and heavier front coils for more lift?
  16. Nov 28, 2008 at 1:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On a PreRunner, yes. On a 4x4, no. :)
  17. Nov 28, 2008 at 1:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    double post
  18. Nov 28, 2008 at 2:01 PM
    dabighi
    sorry chris my mind isnt working today.im pretty much runnin the same set up as u.so it is possible to add the spindles for more lift
  19. Nov 28, 2008 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. :)
  20. Nov 28, 2008 at 2:11 PM
    cmytacoma
    cmytacoma Well-Known Member
    Humboldt county NORCAL
    05 black DC LB sport
    Eclipse AVN 6620, Diamond audio 4.5" component in kicks, center channel with same mid and 2 tweets, infinity kappa perfect component 6.1 in front doors, kappa 6.1 coax in rear, sx900.4, fosgate power 1000, 06 L7 in ported box. BHLM, custom made sliders,
    I think extreme 450 said it best. If you go 3" body I'd personally get the revtek since they have upper and lower so there is Less strain on the CV's. vs others for similar cost. just IMO. Good luck and post pics when done
