Pros/Cons of fiberglass fenders
Discussion in 'Off-Roading & Trails' started by LonghornTaco, Jan 11, 2009.
  1. Jan 11, 2009 at 8:25 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Don't really know much about them except they look pretty wicked. My question is are there any disadvantages of having them on a daily driver? Also, will they provide any benefit if you don't have a long travel kit installed or something?
    I was surprised that the glassworks fenders weren't all that expensive. Of course, I'm sure the expensive part is getting them installed/painted...
  2. Jan 11, 2009 at 8:27 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    it allows you to flex out bigger tires than say 33s without trimming or tubbing the fenderwell
    **Edit** see the Demello Tacoma
  3. Jan 11, 2009 at 8:34 PM
    LonghornTaco
    Minnesota
    Hmm... Wonder if it would look funny with 285s? Not big enough?
  4. Jan 11, 2009 at 8:38 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I'd go with 35"s if your gonna get glass.
    The only disadvantage I could think of is that it makes your truck wider, could make the trails a little tight.
    mahaloTaco likes this.
  5. Jan 11, 2009 at 8:42 PM
    LonghornTaco
    Minnesota
    Yeah, I thought about the added width...
    I don't know, I just thought they look pretty mean...it would be very low on the mod wish list...
  6. Jan 11, 2009 at 8:44 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    look at fiber werx. they are pretty good to or downey off road is way cheaper.
    just look them up.
    i want to get a one peice front for my 95 that will make it look like an 08
  7. Jan 11, 2009 at 8:45 PM
    Hambone155
    omaha
    and 05tacoTRD you better get that camber checked, it looks like you got some posy on that front
  8. Jan 11, 2009 at 8:50 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    i dont think downey makes glass for the 05+
    i just looked on the fiberwerx site...those 1 piece race truck kits look badass!
    and the conversion kits too!
  9. Jan 11, 2009 at 8:53 PM
    Hambone155
    omaha
  10. Jan 12, 2009 at 11:35 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Installation is a pain but it's worth the time. I spent hours sanding each of the front fenders to get everything to line up properly. I still need to buy and install the new bedsides. Do yourself a favor and buy a Dremel if you don't already have one.
    Before:
    After:
    Looks a little goofy on a non-long-travel truck but I wanted them to avoid the chance of sheet metal bending and tearing into my tires.
    There's no standard means of mounting the antenna with these. I zip-tied mine to the truck under the passenger side fender and it's worked for me. Next I need to re-route the air intake since it now sucks in from the wheelwell with nothing protecting it from water spraying up from the tires.
    Biscuits likes this.
  11. Jan 12, 2009 at 1:31 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I know on the 1st gens you can get them with a mild flare on them so it doesnt look wierd without long travel, idk about 05+ but if you can get a set with a mild flare on it with 285's and maybe a some wheels that stick out farther than stock it would look awesome!
  12. Jan 12, 2009 at 1:35 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    mjp2 theres some room and a little area under the intake filter of where u can possibly weld some kind of heat shield to protect it
  13. Jan 12, 2009 at 1:39 PM
    mjp2
    NJ
    I'm torn between that and running it into the passenger compartment. I can deal with noise but the ducting will be a PITA. There's a good chance I'll go with what you suggested as long as I can make sure water drains away from the intake if/when it does get through that opening.
  14. Jan 12, 2009 at 1:41 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    just wrap the intake in a shamwow!
    thecoz likes this.
  15. Jan 12, 2009 at 1:47 PM
    mjp2
    NJ
    That might soak up all the oxygen along with the water! Those things are SUPER absorbent!
    To completely derail the thread for a moment, 36 seconds into this is pure gold:
    http://www.youtube.com/watch?v=pPKtBM99kAc
    rjbiii likes this.
  16. Jan 12, 2009 at 1:49 PM
    tacoskim
    Los Angeles, CA
    Stock
    ahahaha, ur gonna love my nuts
    rjbiii likes this.
  17. Jan 12, 2009 at 2:03 PM
    MacTaco
    MacTaco Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    IMO you almost have to have a LT kit to make the glass fenders look good. Otherwise, the truck has a fat top, and no wide bottom to compensate.
  18. Jan 12, 2009 at 2:16 PM
    absolutkc
    absolutkc Student
    Kansas City
    07 PreRunner SR5
    Kenwood X592
    Tacos, fettucini, linguine, martini, bikini!
  19. Jan 12, 2009 at 2:26 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    x2... :thumbsup:
  20. Jan 12, 2009 at 2:49 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    X3
    tacosupreme671 likes this.
