Protecting undercrraige???
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Nov 9, 2010.
  1. Nov 9, 2010 at 6:58 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
    hey i just wanted to start a thread on how to prevent rust/ protect under carriage. i've heard that 3m make this rubber spraying product that protects but does it work? and suggestions? I've personally tried some what high quality spray paint but it chipping everywhere
    thanks
  2. Nov 9, 2010 at 7:23 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Spay on bed liner works well
  3. Nov 9, 2010 at 7:30 PM
    bowhunter11199
    is it pretty expensive for it? i did my bed and it wasnt too bad
  4. Nov 10, 2010 at 1:56 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    I have tested the 3m undercoating before, its good stuff buy it doesn't dry. It will stay kinda gummy, and dirt sticks to it. To clean the dirt off you need a pressure washer, and it takes the undercoating off too. The bed liner drys good and is hard as a rock.
  5. Nov 10, 2010 at 9:50 AM
    bowhunter11199
    are you able to use that hurculiner stuff for the undercarriage?
  6. Nov 10, 2010 at 1:17 PM
    Nick_Taco
    Nick_Taco Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
  7. Nov 10, 2010 at 1:31 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I get under my truck every year or two to check for rust. If I find some, I'll sand to the frame and repaint with black chassis paint. That's about as cheap as you can go.
    You can also try that rubberized spray, have used it once and worked great. Also could try por-15.
    X2!
  8. Nov 10, 2010 at 3:54 PM
    bowhunter11199
    so i look up por-15. does it allow you to paint directly over the rust without removing it?
  9. Nov 10, 2010 at 3:57 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  10. Nov 10, 2010 at 4:49 PM
    bowhunter11199
    do you remember how much a pint of por-15 will cover? Or do u know how much it will take to cover the undercarriage?
  11. Nov 10, 2010 at 4:58 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    last year i had my whole underside of my truck undercoated at uniglass ziebart in saint john, i knew the manager so he hooked me up with a 400$ undercoating job for only 99$. but for touchups i use rubberized bedliner spray, that stuff works great. i always clean the area before spraying but it adheres really well either way.
  12. Nov 12, 2010 at 9:25 AM
    bowhunter11199
    por-15 says that for the paint to preform weel it must be applied in temps above 65. Well i live in and the temp never gets above 40. so has anyone every used por-15 under 65?
  13. Nov 13, 2010 at 8:36 AM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
  14. Nov 13, 2010 at 5:31 PM
    bowhunter11199
    ya that would work pretty good but i think im still going to take the time to do por-15. and yes its pretty expensive for paint but my truck takes care of me so ill do the same.
