protection for rear slider window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zuter, Jan 20, 2009.
  1. Jan 20, 2009 at 3:20 PM
    zuter
    zuter [OP] Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    Does anybody know of an add-on protection for the rear window. I like to driver around with my rear slider open a crack...and I'm too absent minded to close it when not driving. So I was wondering if there's some bars or screen that can be installed which allows me to open the window and leave it that way without worring that somebody can easily break into it!
  2. Jan 20, 2009 at 3:22 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
  3. Jan 20, 2009 at 4:22 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I don't think that would work too well. It'd be a simple matter to manipulate a hanger into one of those holes, close the window slightly and flip it out.
    Home Depot or Lowes sell little clips that go on a sliding window track and tighten with a flat headed screw (for your fingers). You might see if one of those will fit in the track.
  4. Jan 20, 2009 at 4:48 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    The piece of metal doesn't require 2 holes. Maybe just a flat bar with no holes would work best. But as I understood it, the piece used in the link I posted was a scrap piece he had lying around.
  5. Jan 20, 2009 at 9:05 PM
    Evil Monkey
    Robert
    Escondido, CA
    It would still be relatively easy to pop it out. As long as the crack is wider than a coat hanger, you can close the window until it touches, easing tension off the bar and then flip it out with the hanger end. Something like this would work better:
    http://www.totsafe.com/proddetail.asp?prod=8746w
  6. Jan 20, 2009 at 11:26 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    You could try a 1/4" dowel rod. Paint it black and you would never see it, not to mention cheap insurance < $1.00
  7. Jan 21, 2009 at 5:37 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    What would be sick is a cylinder/actuator that just opens or closes the window via a switch and somehow cannot be pushed open when power is removed (i.e. the truck is off). But I'm sure it wont be a cheap modification not to mention that there's not much room between the seats and the window.
  8. Jan 21, 2009 at 5:57 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    hmm... how very F-150ish... :D
  9. Jan 21, 2009 at 6:52 AM
    dbbd1
    dbbd1 Well-Known Member
    No, it actually fits in the window groove quite snugly, hence the finger holes.
    Yes, it was scrap, but still works good.
    Not as easy as you might think. Also, some guy does not want to be standing in the back of your truck too long messing with trying to get it out. If you want more secure, go with a piece only 1" wide, but do not lose it in the groove. I tried to get it out and I think it does a great job.
  10. Jan 21, 2009 at 9:03 AM
    zuter
    Calgary, AB
    09 SR5 4x4 4 cyl
    Thanks all
    While I think this would work well enough I was looking for something a little different...sorry for not being more discriptive...my bad!
    I was thinking of a set of bars similar to light/turn signal protectors. This could be mounted inside or outside of window and still allow it to be opened/closed.
    See drawing:
